Support for new board with 328ph board
I just purchased several boards that I dont' seem to be able to find much information on them, how to program, etc. I was wondering if there are others that might have more information on them.
I bought off AliExpress "arduino nono mini ultra typec development board chip 340 serial port". It has 3 RGB LEDs at the bottom, a USBC port. The back side has 6 circular pads with no markings (perhaps for a lipo battery???)
Rear View
Top View
Hope its ok to load these images to clarify things.
Anybody have any help, that I can use to program these?
Arduino IDE found Com4 port, I tried to program it as a simple Arduino Nano, but was unable to load the chip...
IDE #2.3.2. Get the error "avrdude: stk500_recv (): programmer is not responding. ... not in sync: resp=0x6a" etc.
It looks like you have one of these:-
You can tell what sort of board you have from the colour of the ON LED when you plug it into a system.
Mind you might need a 340 serial port driver on your laptop as well.
Try using the IDE 1.8.19, although it might not solve the immediate problem it does give you a fighting chance.
The circular pads are for the ISP programmer
Thank you. I did just find some info that I needed to use the "ATMEG328P Old Bootloader". I was than able to send code without errors.
I will check out your link, to see if I can determine what ports the LED's are connected to. There are total 7-LEDs on this thing (3 are RGB for sure). Thanks for taking the time to respond!!
The link looks similar, but not exactly what I have.
Update: I did write a script to output high on ports 0-19. Both Analog and Digital ports did go high/low. But the RGB LED's 1-3 opposite the USB-C port never came on. So still not sure how to control them??????
They might be addressable LEDs. Do you have a link to the board that you bought?
As @sterretje said they might be addressable LEDs. Your original photograph of the board was too low in resolution. But you can check this with your resistance meter.
First remove all the power and measure the resistance between the ground and all four of the pins of the LED1 one of them should show a connection normally the top left.
This is the connections for the normal WS2812 addressable LED.
If you see a connection to ground on the lower right, then they have mounted it upside down.
When you know what way up it is then measure for continuity between the Data In pin and the connections to the pins round the LED. When you find the connection, it is that pin you must direct your WS2812 pixel driver to, using something like the AdaFruit WS2812 LED library.
If you find no connection between the Data In pin on LED1, try probing LED3.
The LEDs are on D2
You can control them using this library
Your posted image actually shows that the 3 LEDs are on D2. That's also expected, because it's the only pin not brought out to the edge.
The six pads on the bottom are likely ICSP connections; that's the exact pin layout, though usually they're for through-hole headers. You can confirm by checking that one pad each are connected to 5V, GND, D13, D12,D11, and (IIRC) RST.
This board would be a nice replacement for the Nano, but I wonder about it's availability longer term.
Thank you, I will check this out.
Thank you for the feedback!!. The +3V is at the lower left corner, and gnd at the upper right corner (oriented with the USB port at the top). Cant verify the data port as it is not brought to a pin. But on the schematic (as remarked) shows it to be pin D2. I will try using that for control by the AdaFruit LED Library next.
I bought them from WCMCU Store in Aliexpress. I just looked and they are currently out of stock (were $2.29 each) https://a.aliexpress.com/_mOeIO1M or search for "arduino nano mini ultra small typec"
I wonder which Processor in the Arduino IDE, will work the best. This one claims to have These specification....
Processor picoPower® 8-bit AVR® RISC-based microcontroller
Flash Memory 32 KB ISP Flash memory with read-while-write capabilities
EEPROM 1024B EEPROM
SRAAM 2 KB SRAM
I/O Lines 23 general purpose
Registers 32 general purpose
Timers three flexible timer/counters with compare modes, internal and external interrupts
UART Serial Programmable (ch340 driver is needed?)
SPI 1 usings pins…..
A/D Converter 1 Six Channel 10-bit A/D converter (8-channels in TQFP and QFN/MLF packages),
Timers
Power Saving
Voltage 1.8 – 5.5 Volts
Arduino What is the best processor to select???
in the IDE select "ATMEG328P Old Bootloader".
A better image of the processor ...
I think you solved that problem in post #3
Yes it did work, and seems ok. Just not sure if it is the optimum board (though the specs to seem similar).
Also an update the Adafruit NeoPixel sketch examples work fine with this little board.
Thanks to all who helped!!!
Define "optimum" board. The generated code for both the "328P" and the "328P old bootloader" is the same; the only difference is in the upload process.
Glad it worked.
Have a nice dat!
Do the digital pins have capacitive touch like the nano?
I have written some code for the Arduino Nano Super Mini 328p with 3 onboard RGBw leds. (old Bootloder)
it is usefull code
  1. it tests comms between ide and nano
  2. it checks LEDS actualy work correctly
  3. the code allows snippets to be taken to turn off LEDS if not needed
written by Brian Forster  30 August 2024
this is a simple program for the Arduino Nano Super Mini
as im using Wikiwo i had to use a stock Nano and external RGBW leds
the purpose is simple
turn off all 3 RGB leds
then turn on Red, Green and Blue after 400ms delay on led 0, 1 and 2
then all go white and repeat
Brightness is easily controlled too
#define PIN 2 // Pin connected to the Neopixel strip
#define NUMPIXELS 3 // Number of pixels in the strip
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
  // Set the brightness level (adjust the value as needed)
  pixels.begin();
  // Turn off all LEDs
  for(int i=-1; i<NUMPIXELS; i++) {
    pixels.setPixelColor(i, pixels.Color(0,0,0));
  pixels.show();
  delay(1000); // Wait for 1 second
  // Check if the LEDs can be powered (e.g., by lighting them up briefly)
  pixels.setPixelColor(0, pixels.Color(255, 0, 0)); // Set the first LED to red
  pixels.setBrightness(128); // 50% brightness
  pixels.show();
  delay(400); // Wait for 0.4 second
 // pixels.setPixelColor(0, pixels.Color(0, 0, 0)); // Turn off the LED
  //pixels.show();
  pixels.setPixelColor(1, pixels.Color(0, 255, 0)); // Set the second LED to green
  pixels.show();
  pixels.setPixelColor(2, pixels.Color(0, 0, 255)); // Set the third LED to blue
  pixels.show();
    pixels.setPixelColor(i, pixels.Color(255,255,255));// all white
  pixels.show();
2 posts were split to a new topic: D2 pin needed 12345
Hi, could anyone helpme find the Eagle library for this new Nano SuperMini board? I want to design an electronic board but I can't find the library for this new Nano SuperMini board.
It looks like that development board uses a atmega328p 28pin vqfn package so, apart from losing pin D2 for the leds, you also lose A6 and A7. It appears that the board pins are not on a simple 0.1" matrix so you'd anyway have to design a PCB for it. If there isn't a ready made footprint available, you'll need to do some accurate measurements and make your own. I'm curious that people have actually found a use for this board.
