Support Regarding to the TFT 3.2 inch LCD
Hello
I am Using Sainsmart 3.2 TFT LCD. now i am facing some problem. Please check this link I am using the Same Interface card and LCD. The Microcontroller is 2560 Mega also from Sainsmart.
My Problem is …. When I upload the Touch Button Sketch into the Controller .He is working Perfectly First Time. After that if I just Unplug the USB and Plug again then my Touch behave like uncalibrated and Most of the time have no response .And some Time behave like frozen.
I am using the the Lastest code from (Link)
i hope some experience guy will help me
Does it work again when you press the reset button?
DrDiettrich: Does it work again when you press the reset button?
thank you for reply
with Reset , the Result are good but not enough. if i try 10 times then LCD work 4 Times and 6 Times not and he Behave like frozen and look like not calibrated.
so i TEST the SIMPLE code thats work so perfectly.
but this Library U_TFT and u_Touch have some issue
here is simple Working Code
#define LCD_RS   38
#define LCD_WR   39
#define LCD_CS   40
#define LCD_REST 41
#define DCLK     6
#define CS       5
#define DIN      4
#define DOUT     3
#define IRQ      2
unsigned int TP_X,TP_Y;
void spistar()                                     //SPI Start
  digitalWrite(CS,HIGH);
  digitalWrite(DCLK,HIGH);
  digitalWrite(DIN,HIGH);
void WriteCharTo7843(unsigned char num)          //SPI Write Data
  unsigned char count=0;
  unsigned char temp;
  unsigned nop;
  temp=num;
  digitalWrite(DCLK,LOW);
  for(count=0;count<8;count++)
    if(temp&0x80)
      digitalWrite(DIN,LOW);
    temp=temp<<1;
    nop++;
    nop++;
    nop++;
    nop++;
unsigned int ReadFromCharFrom7843()             //SPI Read Data
  unsigned nop;
  unsigned int Num=0;
  for(count=0;count<12;count++)
    Num<<=1;
    digitalWrite(DCLK,HIGH);//DCLK=1; _nop_();_nop_();_nop_();
    nop++;
    digitalWrite(DCLK,LOW);//DCLK=0; _nop_();_nop_();_nop_();
    nop++;
    if(digitalRead(DOUT)) Num++;
  return(Num);
void AD7843(void)
  digitalWrite(CS,LOW);
  WriteCharTo7843(0x90);
  TP_Y=ReadFromCharFrom7843();
  WriteCharTo7843(0xD0);
  TP_X=ReadFromCharFrom7843();
void Lcd_Writ_Bus(char VH,char VL)
  unsigned char i,temp,data;
  data=VH;
  for(i=22;i<=29;i++)
    temp=(data&0x01);
    if(temp)
      digitalWrite(i,HIGH);
      digitalWrite(i,LOW);
    data=data>>1;
  data=VL;
  for(i=37;i>=30;i--)
    temp=(data&0x01);
    if(temp)
    data=data>>1;
  digitalWrite(LCD_WR,LOW);
  digitalWrite(LCD_WR,HIGH);
void Lcd_Write_Com(char VH,char VL)
  digitalWrite(LCD_RS,LOW);
  Lcd_Writ_Bus(VH,VL);
void Lcd_Write_Data(char VH,char VL)
  digitalWrite(LCD_RS,HIGH);
void Lcd_Write_Com_Data(int com,int dat)
     Lcd_Write_Com(com>>8,com);
     Lcd_Write_Data(dat>>8,dat);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
      Lcd_Write_Com_Data(0x0044,(x2<<8)+x1);
      Lcd_Write_Com_Data(0x0045,y1);
      Lcd_Write_Com_Data(0x0046,y2);
      Lcd_Write_Com_Data(0x004e,x1);
      Lcd_Write_Com_Data(0x004f,y1);
      Lcd_Write_Com(0x00,0x22);
void Lcd_Init(void)
       digitalWrite(LCD_REST,HIGH);
       delay(5);
       digitalWrite(LCD_REST,LOW);
       delay(15);
       delay(15);
    Lcd_Write_Com_Data(0x0000,0x0001);    delay(1);  //打开晶振
    Lcd_Write_Com_Data(0x0003,0xA8A4);    delay(1);   //0xA8A4
    Lcd_Write_Com_Data(0x000C,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x000D,0x080C);    delay(1);
    Lcd_Write_Com_Data(0x000E,0x2B00);    delay(1);
    Lcd_Write_Com_Data(0x001E,0x00B7);    delay(1);
    Lcd_Write_Com_Data(0x0001,0x2B3F);    delay(1);   //驱动输出控制320*240  0x6B3F
    Lcd_Write_Com_Data(0x0002,0x0600);    delay(1);
    Lcd_Write_Com_Data(0x0010,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0011,0x6070);    delay(1);        //0x4030           //定义数据格式  16位色
    Lcd_Write_Com_Data(0x0005,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0006,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0016,0xEF1C);    delay(1);
    Lcd_Write_Com_Data(0x0017,0x0003);    delay(1);
    Lcd_Write_Com_Data(0x0007,0x0233);    delay(1);        //0x0233
    Lcd_Write_Com_Data(0x000B,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x000F,0x0000);    delay(1);        //扫描开始地址
    Lcd_Write_Com_Data(0x0041,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0042,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0048,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0049,0x013F);    delay(1);
    Lcd_Write_Com_Data(0x004A,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x004B,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0044,0xEF00);    delay(1);
    Lcd_Write_Com_Data(0x0045,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0046,0x013F);    delay(1);
    Lcd_Write_Com_Data(0x0030,0x0707);    delay(1);
    Lcd_Write_Com_Data(0x0031,0x0204);    delay(1);
    Lcd_Write_Com_Data(0x0032,0x0204);    delay(1);
    Lcd_Write_Com_Data(0x0033,0x0502);    delay(1);
    Lcd_Write_Com_Data(0x0034,0x0507);    delay(1);
    Lcd_Write_Com_Data(0x0035,0x0204);    delay(1);
    Lcd_Write_Com_Data(0x0036,0x0204);    delay(1);
    Lcd_Write_Com_Data(0x0037,0x0502);    delay(1);
    Lcd_Write_Com_Data(0x003A,0x0302);    delay(1);
    Lcd_Write_Com_Data(0x003B,0x0302);    delay(1);
    Lcd_Write_Com_Data(0x0023,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0024,0x0000);    delay(1);
    Lcd_Write_Com_Data(0x0025,0x8000);    delay(1);
    Lcd_Write_Com_Data(0x004f,0);        //行首址0
    Lcd_Write_Com_Data(0x004e,0);        //列首址0
void Pant(char VH,char VL)
    int i,j;
  digitalWrite(LCD_CS,LOW);
  Address_set(0,0,239,319);
  for(i=0;i<320;i++)
    for (j=0;j<240;j++)
      Lcd_Write_Data(VH,VL);
  digitalWrite(LCD_CS,HIGH);
  for(int p=22;p<42;p++)
    pinMode(p,OUTPUT);
  for(int p=2; p<7;p++)
      pinMode(p,OUTPUT);
  pinMode(DOUT,INPUT);
  pinMode(IRQ,INPUT);
  Lcd_Init();
 // Pant(0x00,0xff);
  Pant(0xff, 0xff);
  unsigned char flag;
  unsigned char ss[6];
  unsigned int lx,ly;
  spistar();
  while(1)
    flag = digitalRead(IRQ);
    if (flag == 0)
      AD7843();
      lx=((TP_X-340)*10/144);
      //if(lx>237) lx=237;
      ly=320-((TP_Y-320)/11);
      //if(ly<0) ly=0;
      Serial.print("X1  ");
      Serial.print(lx);
      Serial.print("  X2  ");
      Serial.print(lx+2,DEC);
      Serial.print("  Y1  ");
      Serial.print(ly,DEC);
      Serial.print("  Y2  ");
      Serial.println(ly+2,DEC);
      Address_set(lx,ly,lx+2,ly+2);
      Lcd_Write_Data(0,255);
But now i need some Help to put this Library Working.Library makes the Screen Frozen.
It may be a hardware problem. Please check that you connected all pins, including Gnd.
DrDiettrich: It may be a hardware problem. Please check that you connected all pins, including Gnd.
There is No problem in the Hardware. i Already Post the Simple Example as Working Code. the Problem is in the UTouch Library.
i check the Website of the Library owner but it was written there that i do not need to contact him if i am using the Sainsmart TFT.
