Surely there's an easy fix:
On my MEGA 2560 I’m trying to use the tone generator code: http://arduino.cc/en/Tutorial/Tone . First of all I copied the sketch in:
Melody
Plays a melody
circuit:
  • 8-ohm speaker on digital pin 8
created 21 Jan 2010
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
#include “pitches.h”
// notes in the melody:
int melody = {
NOTE_C4, NOTE_G3,NOTE_G3, NOTE_A3, NOTE_G3,0, NOTE_B3, NOTE_C4};
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations = {
4, 8, 8, 4,4,4,4,4 };
// iterate over the notes of the melody:
for (int thisNote = 0; thisNote < 8; thisNote++) {
// to calculate the note duration, take one second
// divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
int noteDuration = 1000/noteDurations[thisNote];
tone(8, melody[thisNote],noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note’s duration + 30% seems to work well:
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
// stop the tone playing:
noTone(8);
// no need to repeat the melody.
And then added a tab to install the library file:
  • Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
Unfortunately after adding these two and saving them, this error code shows at the bottom every time I try to compile the code…
core.a(main.cpp.o): In function main': C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:5: undefined reference to setup’
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:15: undefined reference to `loop’
Please help guys!
My IDE had problems with
 #include "pitches.h"
And with
I think they’re connected.
(It also had problems with “Smiley::cool”, but posting with code tags would have avoided that one)
AWOL:
That’s cus you didn’t have the ArduinoForumSmiley.h library installed, so it couldn’t find the Cool() method in the static Smiley class :stuck_out_tongue:
I added a new tab called "pitches.h", put the tone definitions into it, compiled it, and got the following error message:
Binary sketch size: 3,396 bytes (of a 32,256 byte maximum)
My guess is that the sketch you posted here isn't the sketch you're compiling.
It wouldn't surprise me if you'd copied and pasted this one from a web page, but made a mistake when entering it into your IDE - maybe missed out the */ from the top comment block, which turns the entire code into a comment...?
I struggled with this until I figured out that when adding a tab with the table of tones pasted in, the tab MUST BE NAMED (or renamed) as: pitches.h That way Arduino knows where to look when the sketch code says:
So, can we get help from an editor to clarify the portion of the tutorial regarding adding a tab and renaming it?
Also the add a tab arrow points straight downward on my screen- not to the right as shown in tutorial.
Help us Obi-Wan ( Tom Igoe )
Best regards,
Michael Flynn
Also a tiny typo on that page. "The" should be "Then" :
"The paste in the following code:
  • Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
One more suggestion for the tone tutorial page- I found that the audio hardware works fine with a simple piezo disc connected to pin 8 and ground instead of the 8 ohm speaker + the correct resistor. Is the piezo a valid alternative and a safer circuit from Arduino's standpoint because there is no inductive whiplash from the speaker coil?
mic:
As a general rule of thumb is always better to not drive directly using Arduino a speaker but sending the out signal to an amplifier which drives the speaker. Yes the piezo option is preferable.
I will modify the image to suggest the use of a piezo. Thank you!
So, you connect an 8 ohm speaker to digital pin 8 ?
That is likely to draw a rather large current.
