SVPWM with arduino NANO
I'm developing an Invertec system with arduino nano, firing 6 IGBTs modules, directly with the portb of the arduino (trough an apropiate driver) and obtaining three phases.
In order to obtain the values of timing to firing the IGBTs I use the Space vectorial modulation. It means divide the cycle in 6 sectors, and according to the sector use two configurations of status for the IGBTs"va" and "vb", after that according to the degree in wich the phasor has to go, arduino set the time of each configuration.
The idea is change the frequency of the motor through a potentiometer.
I get the rotation of a squirrel cage motor with the only trouble of get one phase with less current and less voltage.
To obtain the times I'm not using interruptions, I'm using the micros() function, I suspect it could be the trouble.
However my single head can't see the problem. therefore I will put the code here in order to receive some hint or clue about what could be causing this behavior.
int fault_r = A2;
int fault_s = A1;
int fault_t = A0;
int reset_r = A5;
int reset_s = A4;
int reset_t = A3;
int pot  = A7;
int Q1 = 2;
int Q2 = 3;
int Q3 = 4;
int Q4 = 5;
int Q5 = 6;
int Q6 = 7;
int interruptor = 9;
int voltaje_nominal = 380;
int frecuencia_nominal = 50;
int Vll = 380;
int v_link = 536;
float k_motor = 1.0;
int frecuencia = 1;
unsigned long microInterval = 2000;
unsigned long t_switching   = 4000;
unsigned long currentMicros = micros();
unsigned long previousMicros = 0;
unsigned long t_onda;
unsigned long n_intervalos;
int vectoresXonda;
int v_freq;
long ta;
long tb;
long tc;
long tu;
int va;
int vb;
volatile unsigned long contador = 0;
volatile unsigned long cont_intervalo = 0;
volatile unsigned long offset = 0;
volatile int sector = 1;
int grado_actual;
int gradosXvector;
int antiguo_contador;
int copia_intervalo;
int detenerse = 0;
int vector_contador;
int freno = 0;
uint16_t isinTable8[] = {   // sin(x)*1000
  0, 17, 34, 52, 69, 87,104,121,139,156,173, // 0  - 10
  190,207,224,241,258,275,292,309,325,342, // 11 - 20
  358,374,390,406,422,438,453,469,484,500, // 21 - 30
    515,529,544,559,573,587,601,615,629,642, // 31 - 40
  656,669,681,694,707,719,731,743,754,766, // 41 - 50
  777,788,798,809,819,829,838,848,857,866, // 51 - 60
int lectura;
int contador_lecturas = 0;
unsigned long acumulador_lecturas;
int acumulador_frecuencia = 0;
int frecuencia_candidata = 0;
int frecuencia_aux = 0;
int encendido = 0;
void setup(void)
  setup_pines();
  fallas();
void loop(void)
  encendido = on_off();
  if (encendido){
    frecuencia = 1;
    actualiza_frecuencia();
    contador = 1;
    vector_contador = 0;
    offset = 0;
    actualiza_grado();
    actualiza_tiempos();
    actualiza_vector();
    while( encendido ){
      if (fallas()){
        estado_igbt(0);
      manejo_vectorial2();
int on_off(){
  if ( lectura_interruptor() == 0 && encendido == 0 ){
    int verifica= 0;
    for (int i = 0; i < 10; i++){
      if (lectura_interruptor() == 0 ){
        verifica++;
    if (verifica >= 9 ){
      encendido = 1;
      return 1;
  } else if ( lectura_interruptor() == 1 && encendido == 1 ){
    int verifica= 0;
      if (lectura_interruptor() == 1 ){
        verifica++;
      encendido = 0;
      return 0;
  return encendido;
int lectura_interruptor(){
 return digitalRead(interruptor);
void manejo_vectorial2(){
  unsigned long microstep = 0;
  if (contador == 1 ){
    microstep =  tc;
  else  if (contador == 4 || contador == 5 || contador == 8 ) {
    microstep =  tc;
  else if ( contador == 2 || contador == 7){
    microstep =  ta;
  else if ( contador == 3 || contador == 6){
    microstep =  tb;
  if (currentMicros - previousMicros >= microstep) {
    contador++;
    if (contador >= 9)
      contador = 1;
      vector_contador++;
      actualiza_grado();
    control_igbt(); // out to igbts
    if (contador == 4) lectura_usuario();
    previousMicros = currentMicros;
void lectura_usuario(){
  if (contador_lecturas < 25) {
    lectura = analogRead( pot );
    acumulador_lecturas += lectura;
    contador_lecturas++;
  else {
    frecuencia_aux = acumulador_lecturas /500;
    acumulador_lecturas = 0;
    if (frecuencia_aux == frecuencia_candidata ){
      acumulador_frecuencia++;
      if ( acumulador_frecuencia >= 10 ){
        if ( frecuencia != frecuencia_candidata){
         if ( frecuencia < frecuencia_candidata) frecuencia++;
         if ( frecuencia > frecuencia_candidata) frecuencia--;
         if (frecuencia == 0 ) frecuencia =1;
         Serial.println(frecuencia);
    else {
      frecuencia_candidata = frecuencia_aux;
void  control_igbt( ){
  if ( contador == 2 || contador == 7) estado_igbt(va);
  else if ( contador == 3 || contador == 6) estado_igbt(vb);
  else if ( contador == 4 || contador == 5) estado_igbt(7);
  else if ( contador == 1 || contador == 8) estado_igbt(0);
void actualiza_frecuencia(){
  t_onda = 1000000/frecuencia;
  n_intervalos = t_onda/ t_switching;
  vectoresXonda = n_intervalos ;
  gradosXvector = 360/vectoresXonda;
  v_freq = k_motor*frecuencia;
  tu= map(v_freq,1,v_link,10,microInterval-40);
void actualiza_grado(){
  grado_actual = gradosXvector*vector_contador + offset;
  if (grado_actual > 60){
    offset = grado_actual%60;
    sector = sector + grado_actual/60;
    grado_actual = offset;
    if ( sector >= 7 ) sector = 1;
    actualiza_vector();
void actualiza_tiempos(){
  ta = map( ( isinTable8[60 - grado_actual] ),0,1000,0,tu);
  tb = map( ( isinTable8[60] ),0,1000,0,tu);
  tc = ( microInterval -( ta + tb ) );
void actualiza_vector(){
  switch (sector){
  case 1:
    va = 1; // 001
    vb = 3; // 011
  case 2:
    va = 2; // 010
    vb = 3; // 011
  case 3:
    va = 2; // 010
    vb = 6; // 110
  case 4:
    va = 4; // 100
    vb = 6; // 110
  case 5:
    va = 4; // 100
    vb = 5; // 101
  case 6:
    va = 1; // 001
    vb = 5; // 101
void estado_igbt( int ig ){
  switch ( ig ){
  case 7:
    PORTD= B00011100; // 111
  case 6:
    PORTD= B00111000; // 110
  case 5:
    PORTD= B01010100; // 101
  case 4:
    PORTD= B01110000; // 100
  case 3:
    PORTD= B10001100; // 011
  case 2:
    PORTD= B10101000; // 010
  case 1:
    PORTD= B11000100; // 001
  case 0:
    PORTD= B11100000; // 000
void resetear(){
  digitalWrite(reset_r,LOW);
  digitalWrite(reset_s,LOW);
  digitalWrite(reset_t,LOW);
  delay(100);
  digitalWrite(reset_r,HIGH);
  digitalWrite(reset_s,HIGH);
  digitalWrite(reset_t,HIGH);
int fallas(){
  if (falla()){
    if (falla()){
      return 1;
    else return 0;
  else return 0;
int falla(){
  if (digitalRead(fault_r) == 0 || digitalRead(fault_s) == 0 || digitalRead(fault_t) == 0) return 1;
  else return 0;
void setup_pines(){
  pinMode(fault_r, INPUT);
  pinMode(fault_s, INPUT);
  pinMode(fault_t, INPUT);
  pinMode(reset_r, OUTPUT);
  pinMode(reset_s, OUTPUT);
  pinMode(reset_t, OUTPUT);
  // reset active in LOW
  pinMode(pot , INPUT);
  pinMode(interruptor, INPUT_PULLUP);
  pinMode(Q1, OUTPUT);
  pinMode(Q2, OUTPUT);
  pinMode(Q3, OUTPUT);
  pinMode(Q4, OUTPUT);
  pinMode(Q5, OUTPUT);
  pinMode(Q6, OUTPUT);
