SW M590E not working
Hi, I'm planning to start new project with the SW M590E module. But when I try to wire that with Arduino, It not worked. I mean it not powering up. Can someone please help me to connect it properly and get it to work
if you do a web search for SW M590E or m590e arduino you will get many links
horace:
I did. But I couldn't find wiring instructions for arduino.
this shows the connection to an Arduino Mega plus example code
note the level converter or use a 3.3V Arduino such as the Arduino Due
also seen several recommendations to use an external power supply
horace:
GitHub - tehniq3/M590_GPRS: example sketch using GPRS module with M90 from Neoway
This is very important. Thank you so much for your Help
