Swap between two applications with Leonardo
I want the Arduino Leonardo to swap between two apps only once.
Here’s my code, but it does it in loop although I used a condition.
int FLAG = 1;
  Keyboard.begin();
  if(FLAG = 1)
    delay(3000);
    Keyboard.press(KEY_LEFT_ALT);
    Keyboard.press(KEY_TAB);
    Keyboard.releaseAll();
  FLAG = 0;
Thanks for the help.
So, What is your problem ?
-Malhar
MalharD:
-Malhar
I want it to do it only once, but it does it in a loop and it swaps between them again and again.
just put them both in set up
acitta:
I forgot to mention I need this for another project and I don't want this to be in the setup.
from http://www.arduino.cc/en/Reference/If
Beware of accidentally using the single equal sign (e.g. if (x = 10) ). The single equal sign is the assignment operator, and sets x to 10 (puts the value 10 into the variable x). Instead use the double equal sign (e.g. if (x == 10) ), which is the comparison operator, and tests whether x is equal to 10 or not. The latter statement is only true if x equals 10, but the former statement will always be true.
You need to make it if(FLAG == 1)
acitta:
like this
int FLAG = 1;
   Keyboard.begin();
   delay(3000);
  FLAG = 0;
It'll run once and stop.
acitta:
Wow I forgot! Thank you very much!
