For my first project I will (try to) use 2 stepper motors (NEMA17) for a cam slider. For that I bought 2 EasyDrivers, and because I didn't know what to look for in the specs when I ordered them, I'm now stuck with 2 750mA drivers while most nema17 require 1+A... that's not going to work. I've read (on this forum) that A4988 will go up to 2A so they should be good to go. I've found a driver that (probably) should do well, on Ebay.
Will this work OK? My sketch needs the steppers to be in 1/4 mode and this one does that too but I wonder if there are any connecting differences compared to the easy driver? I'm using AccelStepper.
I will use the easy driver to control the shutter using an optocoupler, now that I have to lying around
Thanks for the answers, I thought the 17 was a range of motors as most that I saw had about the same specs. My mistake, its, 1.7inches in size Learn every day.
The motor I'm looking at now (since the ones I've previously ordered went out of stock somehow) are these: Link to steppermotor.
So these should be good for what I need? I only have one motor that's needs some power (to move the dolley, maybe even on a bit of a slope) and one lighter/smaller stepper for the rotation. I will use the new drivers for both.
One thing is not exactly clear and maybe you can help me with this (again). On the EasyDriver I can set the microsteps by setting Ms1 and MS2 to LOW/HIGH (standard HIGH). Does this work the same? I don't have any pins free anymore to control this as a lot of pins are buttons for leverswitches and the LCD menu, I need them to be in 1/4 step.
Thanks Robin, will order a few. I realize that the build quality might be better from pololu but shipping costs to the Netherlands are pretty steep. The Chinese sellers on eBay ship for free or a for a low fee, which keeps thing manageable.
