Swap the values of 2 int variables
Is there an easy was to swap the values of two variables.... I'm doing it the hard way , but there must be a faster, more efficient way.
And on the same subject, If I call a function, how do I return multiple variables to the calling code.
Which is what? XOR? Temporary variable?
Via a struct, via pointers or via references.
When is your homework due?
TolpuddleSartre:
I have found my answer, was searching for the wrong things…
void swapInt(int*a, int *b) {
int c = *a;
*a = *b;
*b = c;
… and it is not homework…
   int c = *a;
   *a = *b;
   *b = c;
That's the pointer way, sooo very C.
Now try the reference way - much more C++.
daba: I have found my answer, was searching for the wrong things...
void swapInt(int*a, int *b) { int c = *a; *a = *b; *b = c; }
... and it is not homework....
Much better done using references instead of pointers:
void swapInt(int &a, int &b) {
  int c = a;
  a = b;
  b = c;
Regards, Ray L.
...and now try without the temporary variable. 8)
TolpuddleSartre: ...and now try without the temporary variable. 8)
No thanks, I'm moving on to other problems to solve....
So what's the advantage of reference over pointers?
sterretje: So what's the advantage of reference over pointers?
More natural - instead of swap (&a, &b); you can write swap (a, b);
OK, can I have arrays of references?
Note that I'm a C programmer pur sang and only two years ago started embracing C++.
sterretje: OK, can I have arrays of references?
Nope.
TolpuddleSartre: Nope.
Thanks.
TolpuddleSartre: More natural ...
That's a subjective statement. It's not to me. And, I'd imaging that the machine code produced is identical. So, my (subjective) answer in this case would be 'minimal'.
