Hello all,
I am trying to swap between different animation voids using an IR remote.
I have already decoded and written down the HEX codes from each of the buttons but am stuck on how to implement this into my code for the two animations i want to switch between.
Below is the code used
#include "FastLED.h"
#include "IRremote.h"
#define NUM_LEDS 96
CRGB leds[NUM_LEDS];
#define DATA_PIN 6
FastLED.addLeds<UCS1903, DATA_PIN, RGB>(leds, NUM_LEDS);
void NewKITT(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
OutsideToCenter(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
CenterToOutside(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
void CenterToOutside(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for(int i =((NUM_LEDS-EyeSize)/2); i>=0; i--) {
setAll(0,0,0);
setPixel(i, red/10, green/10, blue/10);
for(int j = 1; j <= EyeSize; j++) {
setPixel(i+j, red, green, blue);
setPixel(i+EyeSize+1, red/10, green/10, blue/10);
setPixel(NUM_LEDS-i, red/10, green/10, blue/10);
setPixel(NUM_LEDS-i-j, red, green, blue);
setPixel(NUM_LEDS-i-EyeSize-1, red/10, green/10, blue/10);
showStrip();
delay(SpeedDelay);
delay(ReturnDelay);
void OutsideToCenter(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for(int i = 0; i<=((NUM_LEDS-EyeSize)/2); i++) {
setAll(0,0,0);
showStrip();
delay(SpeedDelay);
delay(ReturnDelay);
void LeftToRight(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for(int i = 0; i < NUM_LEDS-EyeSize-2; i++) {
setAll(0,0,0);
showStrip();
delay(SpeedDelay);
delay(ReturnDelay);
void RightToLeft(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for(int i = NUM_LEDS-EyeSize-2; i > 0; i--) {
setAll(0,0,0);
showStrip();
delay(SpeedDelay);
delay(ReturnDelay);
void CylonBounce(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
setAll(0,0,0);
showStrip();
delay(SpeedDelay);
delay(ReturnDelay);
setAll(0,0,0);
showStrip();
delay(SpeedDelay);
delay(ReturnDelay);
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// NeoPixel
strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
// FastLED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
for(int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, green, blue);
showStrip();
NewKITT(0xff, 0, 0, 8, 10, 50);
CylonBounce(0xff, 0, 0, 4, 10, 50);
At the moment this just runs the first animation 'NewKITT' and then the second 'CylonBounce'.
How would i now implement a function which would allow me to press the number 1 on the remote and it plays 'NewKITT' on a loop and if i press 2 on the remote it then plays 'CylonBounce' on loop instead.
Thanks for your time
H
