Hello there, I am trying to swap between two different WAV files, one that is repeating all the time, the second file plays only one time if a condition is true (certain acceleration values). Unfortunately first swap to the conditioned one works but not back to the default file. Sometimes a strange grumble appears after trying to swap back to default - I believe this could be reasoned by some loops trying to play the default sound but something kicks it of the loop.
What I mean: it swaps back to the default sound, enters the loop, but after a few loops comes nothing. See:
12:57:38.727 -> Channels :1
12:57:38.727 -> Sample Rate :22050
12:57:38.727 -> Byte Rate :44100
12:57:38.727 -> Block Align :2
12:57:38.727 -> Bits Per Sample :16
12:57:38.727 -> Data Size :42718
12:57:38.727 -> In loop
12:57:38.727 -> | GyX = 11 | GyY = 6 | GyZ = -3
12:57:38.727 -> | GyX = 11 | GyY = 5 | GyZ = -4
12:57:38.727 -> | GyX = 11 | GyY = 6 | GyZ = -4
12:57:38.727 -> | GyX = 10 | GyY = 6 | GyZ = -3
12:57:38.727 ->
12:57:38.727 ->
12:57:38.727 ->
12:57:38.727 ->
12:57:38.727 ->
12:57:38.727 ->
12:57:38.727 ->
12:57:38.727 ->
I use a slightly changed sketch from this tutorial: https://www.xtronical.com/i2s-ep3/ It was made for only playing one WAV file so I extended the loop to choose between WAV files. Though I am not capable understanding everything inside the sketch - kinda new to microcontrollers. Tell me if you need anything else.
My Code:
// Title: SD Card Wav Player
// Description:
// Simple example to demonstrate the fundementals of playing WAV files (digitised sound) from an SD Card via the I2S
// interface of the ESP32. Plays WAV file from SD card. To keep this simple the WAV must be stereo and 16bit samples.
// The Samples Per second can be anything. On the SD Card the wav file must be in root and called wavfile.wav
// Libraries are available to play WAV's on ESP32, this code does not use these so that we can see what is happening.
// This is part 3 in a tutorial series on using I2S on ESP32. See the accompanying web page (which will also include
// a tutorial video).
// Boring copyright/usage information:
// (c) XTronical, www.xtronical.com
// Use as you wish for personal or monatary gain, or to rule the world (if that sort of thing spins your bottle)
// However you use it, no warrenty is provided etc. etc. It is not listed as fit for any purpose you perceive
// It may damage your house, steal your lover, drink your beers and more.
// http://www.xtronical.com/i2s-ep3
// Includes
#include "SD.h" // SD Card library, usually part of the standard install
#include "driver/i2s.h" // Library of I2S routines, comes with ESP32 standard install
#include<Wire.h>
#define SDA 21
#define SCL 22
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t GyX,GyY,GyZ;
// Defines
// SD Card
#define SD_CS 5 // SD Card chip select
// I2S
#define I2S_DOUT 25 // i2S Data out oin
#define I2S_BCLK 27 // Bit clock
#define I2S_LRC 26 // Left/Right clock, also known as Frame clock or word select
#define I2S_NUM 0 // i2s port number
// Wav File reading
#define NUM_BYTES_TO_READ_FROM_FILE 1024 // How many bytes to read from wav file at a time
// structures and also variables
// I2S configuration
static const i2s_config_t i2s_config =
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX),
.sample_rate = 44100, // Note, this will be changed later
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1, // high interrupt priority
.dma_buf_count = 8, // 8 buffers
.dma_buf_len = 64, // 64 bytes per buffer, so 8K of buffer space
.use_apll=0,
.tx_desc_auto_clear= true,
.fixed_mclk=-1
// These are the physical wiring connections to our I2S decoder board/chip from the esp32, there are other connections
// required for the chips mentioned at the top (but not to the ESP32), please visit the page mentioned at the top for
// further information regarding these other connections.
static const i2s_pin_config_t pin_config =
.bck_io_num = I2S_BCLK, // The bit clock connectiom, goes to pin 27 of ESP32
.ws_io_num = I2S_LRC, // Word select, also known as word select or left right clock
.data_out_num = I2S_DOUT, // Data out from the ESP32, connect to DIN on 38357A
.data_in_num = I2S_PIN_NO_CHANGE // we are not interested in I2S data into the ESP32
struct WavHeader_Struct
// RIFF Section
char RIFFSectionID[4]; // Letters "RIFF"
uint32_t Size; // Size of entire file less 8
char RiffFormat[4]; // Letters "WAVE"
// Format Section
char FormatSectionID[4]; // letters "fmt"
uint32_t FormatSize; // Size of format section less 8
uint16_t FormatID; // 1=uncompressed PCM
uint16_t NumChannels; // 1=mono,2=stereo
uint32_t SampleRate; // 44100, 16000, 8000 etc.
uint32_t ByteRate; // =SampleRate * Channels * (BitsPerSample/8)
uint16_t BlockAlign; // =Channels * (BitsPerSample/8)
uint16_t BitsPerSample; // 8,16,24 or 32
// Data Section
char DataSectionID[4]; // The letters "data"
uint32_t DataSize; // Size of the data that follows
}WavHeader;
// Global Variables/objects
File WavFile; // Object for root of SD card directory
static const i2s_port_t i2s_num = I2S_NUM_0; // i2s port number
int start=1;
long long timestamp;
Wire.begin(SDA, SCL);
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
pinMode(16, INPUT);
Serial.begin(115200); // Used for info/debug
SDCardInit();
i2s_driver_install(i2s_num, &i2s_config, 0, NULL);
i2s_set_pin(i2s_num, &pin_config);
// get the wav file from the SD card
WavFile = SD.open("/wavfile.wav"); // Open the wav file
if(WavFile==false)
Serial.println("Could not open 'wavfile.wav'");
WavFile.read((byte *) &WavHeader,44); // Read in the WAV header, which is first 44 bytes of the file.
// We have to typecast to bytes for the "read" function
DumpWAVHeader(&WavHeader); // Dump the header data to serial, optional!
if(ValidWavData(&WavHeader)) // optional if your sure the WAV file will be valid.
i2s_set_sample_rates(i2s_num, WavHeader.SampleRate); //set sample rate
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print(" | GyX = "); Serial.print(GyX/1325);
Serial.print(" | GyY = "); Serial.print(GyY/1325);
Serial.print(" | GyZ = "); Serial.println(GyZ/1325);
if((abs(GyX/1325) > 12 || abs(GyY/1325) > 12) && start==1){
Serial.println("Start: 1 and Sensor");
WavFile = SD.open("/coolsaber.wav");
start=0;
play_file();
if (start==0) {
Serial.println("Start: 0 and Sensor");
timestamp=millis();
while(abs(millis()-timestamp)<1000) {
PlayWav();
start=1;
play_file();
PlayWav(); //function to actually play the file, needs to be repeated as long as the file should
//play
Serial.println("In loop");
void play_file(){
if(WavFile==false)
Serial.println("Could not open File");
void PlayWav()
static bool ReadingFile=true; // True if reading file from SD. false if filling I2S buffer
static byte Samples[NUM_BYTES_TO_READ_FROM_FILE]; // Memory allocated to store the data read in from the wav file
static uint16_t BytesRead; // Num bytes actually read from the wav file which will either be
// NUM_BYTES_TO_READ_FROM_FILE or less than this if we are very
// near the end of the file. i.e. we can't read beyond the file.
if(ReadingFile) // Read next chunk of data in from file if needed
BytesRead=ReadFile(Samples); // Read data into our memory buffer, return num bytes read in
ReadingFile=false; // Switch to sending the buffer to the I2S
ReadingFile=FillI2SBuffer(Samples,BytesRead); // We keep calling this routine until it returns true, at which point
// this will swap us back to Reading the next block of data from the file.
// Reading true means it has managed to push all the data to the I2S
// Handler, false means there still more to do and you should call this
// routine again and again until it returns true.
uint16_t ReadFile(byte* Samples)
static uint32_t BytesReadSoFar=0; // Number of bytes read from file so far
uint16_t BytesToRead; // Number of bytes to read from the file
if(BytesReadSoFar+NUM_BYTES_TO_READ_FROM_FILE>WavHeader.DataSize) // If next read will go past the end then adjust the
BytesToRead=WavHeader.DataSize-BytesReadSoFar; // amount to read to whatever is remaining to read
BytesToRead=NUM_BYTES_TO_READ_FROM_FILE; // Default to max to read
WavFile.read(Samples,BytesToRead); // Read in the bytes from the file
BytesReadSoFar+=BytesToRead; // Update the total bytes red in so far
if(BytesReadSoFar>=WavHeader.DataSize) // Have we read in all the data?
WavFile.seek(44); // Reset to start of wav data
BytesReadSoFar=0; // Clear to no bytes read in so far
return BytesToRead; // return the number of bytes read into buffer
bool FillI2SBuffer(byte* Samples,uint16_t BytesInBuffer)
// Writes bytes to buffer, returns true if all bytes sent else false, keeps track itself of how many left
// to write, so just keep calling this routine until returns true to know they've all been written, then
// you can re-fill the buffer
size_t BytesWritten; // Returned by the I2S write routine,
static uint16_t BufferIdx=0; // Current pos of buffer to output next
uint8_t* DataPtr; // Point to next data to send to I2S
uint16_t BytesToSend; // Number of bytes to send to I2S
// To make the code eaier to understand I'm using to variables to some calculations, normally I'd write this calcs
// directly into the line of code where they belong, but this make it easier to understand what's happening
DataPtr=Samples+BufferIdx; // Set address to next byte in buffer to send out
BytesToSend=BytesInBuffer-BufferIdx; // This is amount to send (total less what we've already sent)
i2s_write(i2s_num,DataPtr,BytesToSend,&BytesWritten,1); // Send the bytes, wait 1 RTOS tick to complete
BufferIdx+=BytesWritten; // increasue by number of bytes actually written
if(BufferIdx>=BytesInBuffer)
// sent out all bytes in buffer, reset and return true to indicate this
BufferIdx=0;
return true;
return false; // Still more data to send to I2S so return false to indicate this
void SDCardInit()
pinMode(SD_CS, OUTPUT);
digitalWrite(SD_CS, HIGH); // SD card chips select, must use GPIO 5 (ESP32 SS)
if(!SD.begin(SD_CS))
Serial.println("Error talking to SD card!");
while(true); // end program
bool ValidWavData(WavHeader_Struct* Wav)
if(memcmp(Wav->RIFFSectionID,"RIFF",4)!=0)
Serial.print("Invalid data - Not RIFF format");
return false;
if(memcmp(Wav->RiffFormat,"WAVE",4)!=0)
Serial.print("Invalid data - Not Wave file");
return false;
if(memcmp(Wav->FormatSectionID,"fmt",3)!=0)
Serial.print("Invalid data - No format section found");
return false;
if(memcmp(Wav->DataSectionID,"data",4)!=0)
Serial.print("Invalid data - data section not found");
return false;
if(Wav->FormatID!=1)
Serial.print("Invalid data - format Id must be 1");
return false;
if(Wav->FormatSize!=16)
Serial.print("Invalid data - format section size must be 16.");
return false;
if((Wav->NumChannels!=1)&(Wav->NumChannels!=2))
Serial.print("Invalid data - only mono or stereo permitted.");
return false;
if(Wav->SampleRate>48000)
Serial.print("Invalid data - Sample rate cannot be greater than 48000");
return false;
if((Wav->BitsPerSample!=8)& (Wav->BitsPerSample!=16))
Serial.print("Invalid data - Only 8 or 16 bits per sample permitted.");
return false;
return true;
void DumpWAVHeader(WavHeader_Struct* Wav)
Serial.print("Not a RIFF format file - ");
PrintData(Wav->RIFFSectionID,4);
return;
Serial.print("Not a WAVE file - ");
PrintData(Wav->RiffFormat,4);
return;
Serial.print("fmt ID not present - ");
PrintData(Wav->FormatSectionID,3);
return;
Serial.print("data ID not present - ");
PrintData(Wav->DataSectionID,4);
return;
// All looks good, dump the data
Serial.print("Total size :");Serial.println(Wav->Size);
Serial.print("Format section size :");Serial.println(Wav->FormatSize);
Serial.print("Wave format :");Serial.println(Wav->FormatID);
Serial.print("Channels :");Serial.println(Wav->NumChannels);
Serial.print("Sample Rate :");Serial.println(Wav->SampleRate);
Serial.print("Byte Rate :");Serial.println(Wav->ByteRate);
Serial.print("Block Align :");Serial.println(Wav->BlockAlign);
Serial.print("Bits Per Sample :");Serial.println(Wav->BitsPerSample);
Serial.print("Data Size :");Serial.println(Wav->DataSize);
void PrintData(const char* Data,uint8_t NumBytes)
for(uint8_t i=0;i<NumBytes;i++)
Serial.print(Data[i]);
