sweep and ping
i am trying to get my servo to sweep and stop in incremental stages say 0, 45, 90, 135, and 180. i can get the code to stop the servo to do what i want when it is seprate. and the same for the ping code works fine there as well. when i try to get them to work together my servo starts at 90 like i want then goes to 0 and pings and then just sits there even though i have the code for it to go to 180 in the loop. here is a copy of the code pls help me out i just switched from basic micro and havent gotten the chance to get familiar with arduino yet. the bad thing is this is a class project and i have 2 weeks to get it done, i cant figure out what im doing wrong and why the servo just sits at 0 and pings.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
const int pingPin = 8;  //ping sensor pin number
int pos = 90;    // variable to store the servo position
  // initialize serial communication:
  myservo.attach(7);  // attaches the servo on pin 9 to the servo object
  myservo.write(90); //center servo
  delay(1000); //delay 1000ms
void loop(){
  myservo.write(0); //move servo to pos 0
 // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
 // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
   Serial.print(inches);
  Serial.print("in, ");
   delay(100);
  long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
  delay (100);
   myservo.write(180); //move servo to pos 0
//  myservo.write(90); //move servo to pos 0
//  delay(1000);
it seems pretty simple to me i just cant figure out why it wont work what am i missing
drab:
No, you don't. At least not in the code you provided. The code has it go to 90 in setup() and 0 at the top of loop() so it is doing exactly what this code tells it to do.
