First off, I am relatively new to programming using an Arduino, and I am starting with this project for a science fair project.
As for the coding, I have included my the code both in this message and in the attachment link below. I used the 'Servo Sweep' example sketch to base this code off of. Again, I am new to programming, both in general and with an Arduino, so don't be surprised if there are simple mistakes (there will probably be a lot of them haha)
for (pos = 0; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservoa.write(pos); // tell servo to go to position in variable 'pos'
delay(500); // waits 500ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) // goes from 180 degrees to 0 degrees
myservob.write(pos); // tell servo to go to position in variable 'pos'
myservoc.write(pos); // tell servo to go to position in variable 'pos'
myservod.write(pos); // tell servo to go to position in variable 'pos'
myservoe.write(pos); // tell servo to go to position in variable 'pos'
gaellington:
RE: Error message "expected initializer before 'int' "
Are you missing the ";" on the previous line ?
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod, myservoe; // << this line has syntax error, missing ;
int pos = 0; // variable to store the servo position, error message "expected intializer before 'int' "
myservoa.attach(5);
myservob.attach(6);
myservoc.attach(7);
myservod.attach(8);
myservoe.attach(9);
The Ctrl-T (Tools:autoformat) makes the code a lot easier to read.
After removing the superfluous brackets, (and no doubt with them as well), the code compiles fine.
It now looks like this:-
#include <Servo.h>
myservoa.attach(5);
myservob.attach(6);
myservoc.attach(7);
myservod.attach(8);
myservoe.attach(9);
@gaellington, was there an actual question? I don't see one in the original post.
You probably could modify each of your servos positioning code sections to use the millis format from the "blink without delay" example bottom. Use the conditional "if" below part of the code below to enter the servo movement code instead of using delays after the movement.
if (currentMillis - previousMillis >= interval) {
// save the last time you moved servo
//move servo
/* Blink without Delay
Turns on and off a light emitting diode (LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
* LED attached from pin 13 to ground.
* Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
modified 11 Nov 2013
by Scott Fitzgerald
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to set a pin number :
const int ledPin = 13; // the number of the LED pin
// Variables will change :
int ledState = LOW; // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change :
const long interval = 1000; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
