sweep servo not working ???
Hi all
I have my sweep servo pluged in but it doesnt work it is pluged into termanal 6 and has seperate power supply the others work fine but not the sweep servo iam not using the srfo5 sensor
can any one explain why??
here is the code i stole):
int sensorIR = 0;
int sensorUS = 7;
int calibIR = 10000;
int valIR;
int valUS;
int sensorPot = 2;
int valPot;
int button = 5;
int valButton;
int turnOnOff=0;
int servoTU = 8;
int servoLF = 9;
int servoLB = 10;
int servoRF = 11;
int servoRB = 12;
unsigned long lastPulseR;
unsigned long lastPulseL;
unsigned long lastPulseTU;
int pulseWidthR = 1250;
int pulseWidthL = 1750;
int pulseWidthRTU = 0;
int pulseWidthLTU = 0;
int pulseWidthTU = 1710;
int centerTU = 1430;
int rangeTU=1360;
int refreshTimeServoL = 20;
int refreshTimeServoR = 20;
int refreshTimeServoTU = 20;
int led=3;
int angleDepart=0;
signed long angle=0;
int angleMin=-45;
int angleMax=45;
int nbAngle;
int distance[180];
int distanceMax[18];
int distanceMin[18];
int distanceMoy[18];
int direction[18];
int directionTU;
int sensTU=1;
int turn=0;
int n;
void servoL(int pulseWidth){
if(millis()-lastPulseL >= refreshTimeServoL){
digitalWrite(servoLF,HIGH);
digitalWrite(servoLB,HIGH);
delayMicroseconds(pulseWidth);
digitalWrite(servoLF,LOW);
digitalWrite(servoLB,LOW);
lastPulseL=millis();
void servoR(int pulseWidth){
if(millis()-lastPulseR >= refreshTimeServoR){
digitalWrite(servoRF,HIGH);
digitalWrite(servoRB,HIGH);
digitalWrite(servoRF,LOW);
digitalWrite(servoRB,LOW);
lastPulseR=millis();
int servoT(int pulseWidth){
if(millis()-lastPulseTU >= refreshTimeServoTU){
digitalWrite(servoTU,HIGH);
digitalWrite(servoTU,LOW);
lastPulseTU=millis();
return 1;
return 0;
int getPulseT(){
int pulse;
if(angle<=angleMin){
sensTU=0;
// displaySonar();
//directionTU=getDirection();
if(angle>=angleMax){
// displaySonar();
sensTU=1;
return (centerTU+((angle)*rangeTU/90));
int readSensorIR(){
return (calibIR/analogRead(sensorIR));
void setLed(int valLed){
analogWrite(led,valLed);
int readSensorUS(){
pinMode(sensorUS, OUTPUT);
digitalWrite(sensorUS, LOW);
delayMicroseconds(2);
digitalWrite(sensorUS, HIGH);
delayMicroseconds(10);
pinMode(sensorUS, INPUT);
return(pulseIn(sensorUS, HIGH)/58);
int readSensorPot(){
return (centerTU+long(analogRead(sensorPot))*1000/1024-500);
int readButton(){
unsigned long contactTime;
valButton=analogRead(button);
//Serial.print(valButton);
//Serial.print(" “);
if(valButton<512)
return turnOnOff;
contactTime=millis();
while(valButton>=512){
//Serial.print(”\n");
if(millis()-contactTime<20)
return turnOnOff;
angle=angleDepart;
return(1-turnOnOff);
int getDirection(){
int angle=0,i,j,n=0,seg=0,dir=4,maxSeg=0;
for(i=0;i<18;i++){
distanceMax*=0;*
_ distanceMin*=10000;_
_ distanceMoy=0;
for(j=0;j<5;j++){
if(distance[n+j]>distanceMax)
distanceMax=distance[n+j];
if(distance[n+j]<distanceMin)
distanceMin=distance[n+j];
distanceMoy=distance[n+j];
//Serial.print(distance[n+j]);
//Serial.print(" ");
direction=0;
if(distanceMax>110&&distanceMin>55&&distanceMoy>77){
seg++;
if(seg>maxSeg)
maxSeg=seg;
direction=seg;
else*
* seg=0;
n+=5;
for(i=0;i<18;i++){
if(direction==maxSeg){
dir=i-maxSeg/2;
dir=dir5-40;
// Serial.print(direction);
}*_
//Serial.print(" dir ");
// Serial.print(" \n");
*return dir; *
void displaySonar(){
* int n;*
* for(n=0;n<nbAngle;n++){*
* Serial.print(distance[n]);*
* Serial.print(" ");*
Serial.print("\n");
void pilote2(int valUS,int valTU){
* int acc=0;*
* directionTU=getDirection()/5;*
_ acc=(30max(min(valUS,100),3)/100)-8;
// Serial.print(acc,DEC);
//Serial.print("acc “);
// Serial.print(directionTU);
// Serial.print(” ");
pulseWidthR = min(max(pulseWidthR-acc-directionTU,1250),1750);
pulseWidthL = max(min(pulseWidthL+acc-directionTU,1750),1250);*_
* // Serial.print(pulseWidthR,DEC);*
* // Serial.print("pR ");*
* // Serial.print(pulseWidthL,DEC);*
* // Serial.print("pL ");*
* //Serial.print("\n");*
void pilote(int valUS,int valTU){
* int acc=0,dirR=75,dirL=75;*
* directionTU=getDirection();*
* if(directionTU>0){*
* dirR=75;*
_ dirL=75-150directionTU/45;
if(directionTU<0){
dirL=75;
dirR=75-150directionTU/45;
* }*_
_ acc=(30max(min(valUS,100),3)/100)-15;
//Serial.print(acc,DEC);
//Serial.print("acc ");
//Serial.print(directionTU);
// Serial.print("directU ");*_
* //Serial.print(dirL);*
* //Serial.print(" dirL ");*
* // Serial.print(dirR);*
* //Serial.print("dirR ");*
* pulseWidthL = max(min(pulseWidthL+acc,1675),1325);*
* pulseWidthR = min(max(pulseWidthR-acc,1325),1675);*
* pulseWidthL = max(min(pulseWidthL+dirL,1750),1250); *
* pulseWidthR = min(max(pulseWidthR-dirR,1250),1750);*
* // Serial.print("\n");*
void setup(){
* pinMode(servoTU,OUTPUT);*
* pinMode(servoLF,OUTPUT);*
* pinMode(servoLB,OUTPUT);*
* pinMode(servoRF,OUTPUT);*
* pinMode(servoRB,OUTPUT);*
* pinMode(sensorUS,INPUT);*
* pinMode(button,INPUT);*
* pinMode(13,OUTPUT);*
* lastPulseL=millis();*
* lastPulseR=millis();*
* lastPulseTU=millis();*
* nbAngle=angleMax-angleMin;*
* for (int n=0;n<nbAngle;n++)*
* distance[n]=100;*
*void loop(){ *
* turnOnOff=readButton();*
// Serial.print(turnOnOff);
// Serial.print(" ");
* valIR=readSensorIR();*
_ setLed((100-min(max(valIR,0),100))*1024/100);_
// Serial.print(valIR,DEC);
// Serial.print("cm ");
* valUS=readSensorUS();*
// Serial.print(valUS);
* if(turnOnOff==1){*
* pilote2(valUS,valIR);*
* servoL(pulseWidthL);*
* servoR(pulseWidthR);*
* turn=servoT(getPulseT());*
* if(turn==1){*
* distance[angle+angleMax]=valIR;*
* if(sensTU==1)*
* angle=angle-1;*
* else*
* angle=angle+1;*
* else{*
* valPot=(valPot+readSensorPot())/2;*
* servoT(valPot);*
* //Serial.print(valPot);*
* //erial.print(" \n");*
If you go back to your post, click on "modify", then highlight all the code, then click on the # icon in the editor toolbar, your code will be neatly presented and legible in a proper code box, without italics.
Why in heavens name are you re-implementing the Servo library?
