Sweeperino error messages
I was trying to compile the following code into the Arduino IDE (1.0.5) . I get the error messages as per the screen grab attachment at the end . I will be very grateful if some experienced forum members can tell me how to correct the same .Thanks in advance for your time.
(Nivar)
#include <Wire.h>
#include <SPI.h>
#include <Si570.h>
#include <si5351.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
/* #include <ssd1306_tiny.h>
ssd1306_tiny display; */
Si5351 si5351;
Si570 *si570=NULL;
#define SI570_I2C_ADDRESS 0x55
char printBuff[20];
#define LOG_AMP A3
//#define WB_POWER_CALIBERATION (-112)
#define WB_POWER_CALIBERATION (-92)
int dbm_reading = 100;
int power_caliberation = WB_POWER_CALIBERATION;
char serial_in[32], c[30], b[30];
unsigned char serial_in_count = 0;
long frequency, fromFrequency=14150000, toFrequency=30000000, stepSize=100000;
#define TUNING A2
int tune, previous = 500;
int count = 0;
int i, pulse;
unsigned long baseTune = 14200000;
boolean sweepBusy = false;
/* display routines */
void printLine1(char *c){
if (strcmp(c, printBuff)){
lcd.setCursor(0, 0);
lcd.print(c);
strcpy(printBuff, c);
count++;
void printLine2(char *c){
lcd.setCursor(0, 1);
lcd.print(c);
char *readNumber(char *p, long *number){
*number = 0;
sprintf(c, "#%s", p);
while (*p){
char c = *p;
if ('0' <= c && c <= '9')
*number = (*number * 10) + c - '0';
p++;
return p;
char *skipWhitespace(char *p){
while (*p && (*p == ' ' || *p == ','))
p++;
return p;
/* command 'h' */
void sendStatus(){
Serial.write("helo v1\n");
sprintf(c, "from %ld\n", fromFrequency);
Serial.write(c);
sprintf(c, "to %ld\n", toFrequency);
Serial.write(c);
sprintf(c, "step %ld\n", stepSize);
Serial.write(c);
void setFrequency(unsigned long f){
if (si570 != NULL)
si570->setFrequency(f);
si5351.set_freq(f, 0, SI5351_CLK1);
frequency = f;
/* command 'g' to begin sweep
each response begins with an 'r' followed by the frequency and the raw reading from ad8703 via the adc */
void doSweep(){
unsigned long x;
int a;
sweepBusy = 1;
Serial.write("begin\n");
printLine1("Sweeping...");
for (x = fromFrequency; x < toFrequency; x = x + stepSize){
setFrequency(x);
delay(10);
a = analogRead(LOG_AMP) * 2 + (power_caliberation * 10);
sprintf(c, "r%ld:%d\n", x, a);
Serial.write(c);
Serial.write("end\n");
// si5351.set_freq(fromFrequency, 0, SI5351_CLK1);
sweepBusy = 0;
/* command 'e' to end sweep */
void endSweep(){
//to be done
void readDetector(){
int i = analogRead(3);
sprintf(c, "d%d\n", i);
Serial.write(c);
void parseCommand(char *line){
char *p = line;
char command;
while (*p){
p = skipWhitespace(p);
command = *p++;
switch (command){
case 'f' : //from - start frequency
p = readNumber(p, &fromFrequency);
setFrequency(fromFrequency);
case 't':
p = readNumber(p, &toFrequency);
case 's':
p = readNumber(p, &stepSize);
case 'v':
sendStatus();
case 'g':
sendStatus();
doSweep();
case 'r':
readDetector();
case 'o':
case 'w':
case 'n':
case 'i': /* identifies itself */
Serial.write("iSweeperino 2.0\n");
end of the while loop */
void acceptCommand(){
int inbyte = 0;
inbyte = Serial.read();
if (inbyte == '\n'){
parseCommand(serial_in);
return;
if (serial_in_count < sizeof(serial_in)){
serial_in[serial_in_count] = inbyte;
serial_in_count++;
serial_in[serial_in_count] = 0;
lcd.begin(16, 2);
printBuff[0] = 0;
printLine1("Sweeperino v0.02");
// Start serial and initialize the Si5351
analogReference(DEFAULT);
Serial.println("*Sweeperino v0.02\n");
Serial.println("*Testing for Si570\n");
si570 = new Si570(SI570_I2C_ADDRESS, 56320000);
if (si570->status == SI570_ERROR) {
printLine1("Si570 not found");
Serial.println("*Si570 Not found\n");
si570 = NULL;
Serial.println("*Si5350 ON");
printLine2("Si5351 ON");
delay(10);
else {
Serial.println("*Si570 ON");
printLine2("Si570 ON");
setFrequency(14500000);
previous = analogRead(TUNING)/2;
void updateDisplay(){
int j;
sprintf(b, "%9ld", frequency);
sprintf(c, "%.3s.%.3s.%3s ", b, b+3, b+6);
printLine1(c);
sprintf(c, " %d.%d dbm ", dbm_reading/10, abs(dbm_reading % 10));
printLine2(c);
void doReading(){
int new_reading = analogRead(LOG_AMP) * 2 + (power_caliberation * 10);
if (abs(new_reading - dbm_reading) > 4){
dbm_reading = new_reading;
updateDisplay();
void doTuning(){
tune = analogRead(TUNING);
if (tune < 20){
count++;
if (count < 20){
baseTune -= 1000;
setFrequency(baseTune);
updateDisplay();
delay(100);
else if (count < 60) {
baseTune -= 10000;
updateDisplay();
delay(100);
else {
baseTune -= 500000;
updateDisplay();
return;
if (tune > 1000){
count++;
if (count < 20){
baseTune += 1000;
setFrequency(baseTune + 100000);
updateDisplay();
delay(100);
baseTune += 10000;
updateDisplay();
delay(100);
else {
baseTune += 500000;
updateDisplay();
return;
count = 0;
if (previous != tune){
setFrequency(baseTune + (100L * (unsigned long)(tune-20)));
updateDisplay();
previous = tune;
void loop(){
if (Serial.available()>0)
acceptCommand();
if (!sweepBusy){
doReading();
doTuning();
delay(100);
Sweeprino error messages.txt (1 Bytes)
Which you failed to attach.
Attaching text (the compiler output) as a picture is a waste of bandwidth. Post it as TEXT! Read the stickies at the top of the forum, and fix your post so the code is posted properly.
Post your code between code tags, not inline. </> in the post and "Reply" windows.
As Paul says, just post the compiler output.
You didn't even attach it in the end - the text document you attached is blank - 0 bytes.
If you really want help here on the forums, help us to help you by making it as easy as possible.
It's not too late to edit your post and correct these mistakes.....
