hey folks, so i came across some similar posts on this forum, but none that really help me.
So i have this project going, wherein, when i type in a particular word in processing it will - 1) play an appropriate video on processing, 2) send a serial value to arduino which changes the light of a rgb led strip & 3) triggers off the motor to turn from 0 to 180 and back to 0 and then STOP. now the problem is im not able to code this desired sweep action on the servo motor only ONCE. any ideas how to do that?? im quite a arduino / processing noob btw. here is the code. please help! #include <Servo.h>
Servo myservo;
char val; // Data received from the serial port
int greenPin = 11;
int redPin = 10;
int bluePin = 9;
int posTarget = 0;
int posLastSet = 180;
// Set the pin to digital I/O 13
pinMode(greenPin, OUTPUT); // Set pin as OUTPUT
pinMode(redPin, OUTPUT);
pinMode(bluePin, OUTPUT);
myservo.attach(8); // attaches the servo on pin 8 to the ser
Serial.begin(9600); // Start serial communication at 9600 bps
if (Serial.available())
{ // If data is available to read,
val = Serial.read(); // read it and store it in val
//myservo.write(0);
if (val == '0')
{ // If 1 was received
analogWrite(greenPin, 0);
analogWrite(redPin, 0);
analogWrite(bluePin, 255);
//myservo.attach(8);
myservo.write(posLastSet);
/*if(posTarget != posLastSet){
myservo.write(posTarget);
posLastSet = posTarget;
// turn the LED on
} else if ( val == '1') {
analogWrite(redPin, 255);
analogWrite(bluePin, 0);
//myservo.write(0);
// otherwise turn it off
} else if ( val == '2'){
analogWrite(greenPin, 255);
} else // leave the light at a dim white
analogWrite(greenPin, 25);
analogWrite(redPin, 25);
analogWrite(bluePin, 25);
delay(10); // Wait 10 milliseconds for next reading
/*if (val == 'a'){
myservo.write(180);
} else if (val == 'b'){
myservo.write(0);
myservo.write(0);
make it a part of the same condition
by this do you mean, that i make an array of the values 0,1,2??
also the while(1); worked perfectly, but because of that, the next time arduino receives the value '0', the motor does nothing. thats not how i want it. i need it to sweep once every time a '0' value comes in...
thanks
You have a condition based on whether there is serial data available to read.
If there is, you do only one thing, which is to read that data.
I'm saying, why not make everything conditional upon that one thing
so here is the code. both processing & arduino. again, not the most well written, but seems to be doing the job pretty well!
PROCESSING CODE
import processing.serial.*;
import processing.video.Movie;
import ddf.minim.spi.*;
import ddf.minim.signals.*;
import ddf.minim.*;
import ddf.minim.analysis.*;
import ddf.minim.ugens.*;
import ddf.minim.effects.*;
Minim minim;
static final int QTY = 3;
static final int QTY2 = 3;
final Movie[] movies = new Movie[QTY];
final AudioPlayer[] players = new AudioPlayer[QTY2];
int[][] myArray = new int[QTY][QTY2];
int idx;
int index;
String typing = "";
String saved = "";
Serial myPort;
size(200, 200, JAVA2D);
frameRate(30);
noSmooth();
String portName = Serial.list()[2]; //change the 0 to a 1 or 2 etc. to match your port
myPort = new Serial(this, portName, 9600);
movies[0] = new Movie(this, "sin_city.mp4");
movies[1] = new Movie(this, "blue_velvet.mp4");
movies[2] = new Movie(this, "finale.mp4");
minim = new Minim(this);
players[0] = minim.loadFile("one.mp3");
players[1] = minim.loadFile("two.mp3");
players[2] = minim.loadFile("three.mp3");
void draw() {
background(0);
set(0,0,movies[idx] );
void movieEvent(Movie m) {
m.read();
void keyPressed() {
if (key == '\n' ) {
saved = typing;
typing = ""; // A String can be cleared by setting it equal to ""
int k = keyCode, n = getMovieIndex(k) ;
if ( n == 0){
myPort.write('0');
else if (n == 1){
myPort.write('1');
else if (n == 2){
myPort.write('2');
if ( n>=0 & n != idx){// if string typed is NOT the same as previous string then...
index = int(random(2));
else if( n>=0 & n == idx){// if string typed is the same as previous string...
if(index == 0){
index = 1;
else if (index == 1){
index = 0;
//println(index);
else {
// Otherwise, concatenate the String
// Each character typed by the user is added to the end of the String variable.
typing = typing + key;
if (n >= 0 & n!= idx){// if string typed is NOT the same as previous string then...
println(n);
if (index == 0){
movies[idx].pause();
players[idx].pause();
movies[idx = n].play();
players[idx = n].play();
else if ( n >= 0 & n == idx ){// if string typed is the same as previous string...
println(n);
if (index == 0){
else{
println(n);
int getMovieIndex(int k){
if ( saved.equals("blue")){
return 0;
else if(saved.equals("red")){
return 1;
else if(saved.equals("green")){
return 2;
else {
return -1;
ARDUINO CODE
#include <Servo.h>
Servo myservo;
int greenPin = 11;
int redPin = 10;
int bluePin = 9;
myservo.write(0);
analogWrite(greenPin, 220);
if (Serial.available() > 0){ // If data is available to read,
if (val == '0') { // change color to BLUE
myservo.write(180); //
delay(1000); // turn servo back and forth 180 degrees, ONCE
myservo.write(0); //
else if ( val == '1') { // change color to RED
else if ( val == '2'){ // change color to GREEN
