sweeping servo
Hi I am trying to sweep a servo pause for a period of time and sweep again or a series of sweeps.
This is what i have written.
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
servo();
delay(200);
void servo();
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
I am getting an error message servo was not declared in this scope. help
I think you are missing a:
#include <Servo.h>
at the start of your sketch, so the IDE can locate the servo library and include it with your sketch.
Lefty
Lefty ,it is there i just failed to copy it when i pasted the sketch. It is highlighting thethe first servo after void loop and telling me it was not declared in this scope.
Peter
I’d lose the semicolon
void servo()[glow=red,2,300];[/glow]
loosing the semi-colon added another error message. and adding back cleared that one . I am not telling it something about this state and I do not now what, how do you declare.
Peter
Look at the how "loop" is declared, then look at how you have declared "servo"
AWOL ihave followed your lead and taken out the void semi-colon and gotten another error message and returned it and gotten rid of that one, renamed the loops sweeps thinking I had a conflict in the names. still getting the "name" not declared in this scope.
Peter
this is how its writtin currently
#include <Servo.h>
sweep(0);
delay(200);
void sweep(int duration);
Just the one error message
   sweep(0);
   delay(200);
The sweep function that you are trying to define is all wrong. First, it is inside of the loop() function. Functions CAN NOT be nested.
Second, function declarations do not end with a semicolon.
This code will at least compile.
#include <Servo.h>
   sweep(0);
   delay(200);
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
