Sweeping without delay
Hi!
When I use this code for sweeping two servos in opposite direction I get a problem… the problem is that ch4 gets really high values when ch3 goes over 1600 (like 15.000). Could you guys help me out?
Thanks!
int ch2;
int ch3;
int ch4;
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;            // create servo object to control a servo
                        // twelve servo objects can be created on most boards
int pos1 = 0;           // variable to store the servo position
int pos2 = 90;
class Sweeper1
  Servo servo1;              // the servo
  int pos;                   // current servo position
  int increment;            // increment to move for each interval
  int  updateInterval;      // interval between updates
  unsigned long lastUpdate; // last update of position
public:
  Sweeper1(int interval)
    updateInterval = interval;
    increment = 1;
  void Attach(int pin)
    servo1.attach(pin);
  void Detach()
    servo1.detach();
  void Update()
    if((millis() - lastUpdate) > updateInterval)  // time to update
      lastUpdate = millis();
      pos += increment;
      servo1.write(pos);
      Serial.println(pos);
      if ((pos >= 90) || (pos <= 0)) // end of sweep
        // reverse direction
        increment = -increment;
class Sweeper2
  Servo servo2;              // the servo
public:
  Sweeper2(int interval)
    increment = 1;
    servo2.attach(pin);
  void Detach()
    servo2.detach();
  void Update()
      pos -= increment;
      servo2.write(90-pos);
Sweeper1 sweeper1(5);
Sweeper2 sweeper2(5);
  pinMode(3, INPUT);
  pinMode(5, INPUT);
  pinMode(6, INPUT);
  pinMode(9, INPUT);
  servo3.attach(7);
  servo4.attach(8);
  sweeper1.Attach(2);
  sweeper2.Attach(4);
Serial.println("Table");
  ch2 = pulseIn(5, HIGH);
   Serial.print (", Ch2:"); Serial.print (ch2);
  ch3 = pulseIn(6, HIGH);
   Serial.print (", Ch3:"); Serial.print (ch3);
  ch4 = pulseIn(9, HIGH);
   Serial.print (", Ch4:"); Serial.print (ch4);
// Sweeping-condition
if (ch3 >= 1600 && 1400 <= ch4 && ch4 <= 1600) {
  sweeper1.Update();
  sweeper2.Update();
Can you explain why Sweeper1 looks so much like Sweeper2 ?
Because I want it to the same but swipe in the opposite direction. Maybe there is a easier way? I'm new to this kind of programming.
EDIT: Sorry, forgot to change the Sweeper2. In the if-loop it should be a - instead of +. Edited it now in the code.
A single class with a extra boolean member flag that tells the class to do write "90 - angle" - it's be a whole lot shorter.
Ok, thanks. But I have still the problem that ch4 gets really hugh values when ch3>1600.. any ideas there?
