Hi guys. I'm very nooby in arduino. I've bought a starter kit a few days before and played with it a little bit.
Now I would like to create my first real life project. I want to develop a swing door opener system.
I need:
Servo which put the door knob down.
Servo for opening the door. This servo should open and close the door
I thought to do something like this, but a little bit smaller.
But I don't really know what kind of servo should I use. Could anybody tell me what will be suitable for my case, please?
Regular size person door? Then you need something bigger than a RC hobby servo. I can't think of any that will be able to move a door.
Your photo shows that this kind of thing does exist as a commercial product. I can't see a homemade prototype getting any smaller than what you showed. Why not buy one of them?
AND powerful door openers need suitable safeguards to prevent injury, and to allow emergency override which will make the project a a lot more complex.
MorganS:
Yes, the regular size door. It's door to balcony. Do you think I need really powerful servo? Because the door pretty light and I thought the 15 kg/cm will be enough. Am I wrong?
MorganS:
Because I cant find any for reasonable price. The cost is more than 1000$. And the second reason is that I want to open the door knob from one remote control. And I think there is no product like this.
I cant use actuator, because I need to open the door manually sometimes.
There is a link in the description below the video. But I didn't understand what kind of motor he uses. Because.
Robin2:
...R
I think for the first time I don't need any safeguards.
mqdb:
Try to measure the torque you use to open the door manually. I think you need a lot more than 15kg/cm.
mqdb:
And that makes the project significantly more complex.
MorganS:
Could you tell me, please, how I can do it?
MorganS:
I'm sorry for silly questions, but why more complex? Servo may be turned manually, mayn't it?
Guys, have you watched the video from youtube which I sent? For nooby like me it's kind of complicated, but I think it's not so complicated in general. There are just one motor. I think the most complicated part is to find out the type of the motor.
You know what kg-cm or foot-pound means? Were you awake in highschool physics? It's force times distance. 15kgcm is a force of 15kg at 1cm from the hinge. Or it's 1kg at 15cm from the hinge. (Not that kg is a unit of force but convention says that it's 9.8N.) Try to pick up a 1L container of milk with just one finger to feel how heavy 1kg is. Then apply that force 15cm from the hinge of your door.
I don't know about the servo you found but most actuators above that size can't be pushed manually.
MorganS:
If I'm not mistaken, open the door need less force than to lift 1 kg to 15 cm. Do you think Power HD 1201MG won't be enough to open the door?
Paul_KD7HB:
Change the door "knob" to a lever and you will have many more options to activate it.
Lawsuits from injuries due to automatic door openers come from automatic closing. If you are only opening, then pretty safe.
Also, are the property owner? If not, then the owner will also be liable for what you do, even if they are unaware of your project.
Paul
Thank you for your response, Paul. Unfortunately I can't change the knob, because it's a balcony door and it has a specific structure.
The door is in my house. So I think I shouldn't be afraid of lawsuits. However, there won't be so powerful motor and it won't be able to make any hurts.
mqdb:
An electric clutch could po$$ibly work for you. When clutch is deenergized door opens as per normal. When clutch is energized door moves under influence of torque source.
