switch 3 ways with counter
Hi guys, can i make this more clean?
im trying the counter reach in 3 when a specific order of switch on (like 2nd, 1st, 3rd).
this switch
this only to u know how is wired
this i figured out, but if u can help me, i appreciate
int portInt[] = {9, 10, 11, 12, 13, 24};
int led5[]= {53, 51, 49};
 for (int l5 = 0; l5 <= 3; l5++) {
  pinMode(led5[l5], OUTPUT);
 for (int pI = 0; pI <= 5; pI++) {
  pinMode(portInt[pI], INPUT);
  interruptores();
void RGB_5(int r5_value, int g5_value, int b5_value)
  analogWrite(led5[0], r5_value);
  analogWrite(led5[1], g5_value);
  analogWrite(led5[2], b5_value);
void interruptores()
static int countInt = 0;         // variable for reading the pushbutton status
Serial.println(countInt);
  if (countInt == 3) {
  digitalWrite(led5[0], HIGH);
  digitalWrite(led5[0], LOW);
  if ((digitalRead(portInt[4]) == LOW) && (digitalRead(portInt[2]) == LOW) && (digitalRead(portInt[0]) == LOW)) {
    countInt = 0;
  if ((digitalRead(portInt[4]) == HIGH) && (digitalRead(portInt[0]) == LOW)) {
  countInt--;
  if ((digitalRead(portInt[0]) == HIGH) && (digitalRead(portInt[2]) == LOW)) {
  countInt--;
  if ((digitalRead(portInt[2]) == HIGH) && (countInt == 0)) {
  countInt++;
  if ((digitalRead(portInt[0]) == HIGH) && (countInt == 1)) {
  countInt++;
  if ((digitalRead(portInt[4]) == HIGH) && (countInt == 2)) {
  countInt++;
  if ((digitalRead(portInt[1]) == HIGH) || (digitalRead(portInt[3]) == HIGH) || (digitalRead(portInt[5]) == HIGH)) {
  countInt--;
Look at the State Change Detection example in the IDE (File->examples->02.Digital->State Change Detection). to figure out how to detect when a switch changes state. This change of state is when you want to react, not keep increasing/decreasing you counter simply because a switch is HIGH or LOW.
is this of any help (had only 3 push-buttons)
#if 0
#else
#define ON  LOW
#define OFF HIGH
byte portInt [] = { A1, A2, A3 };
byte led5    [] = { 10, 11, 12};
#endif
void setup () {
    for (int i = 0; i < sizeof (led5); i++) {
        digitalWrite (led5 [i], OFF);
        pinMode (led5 [i], OUTPUT);
    for (int i = 0; i < sizeof(portInt); i++) {
        pinMode (portInt [i], INPUT);
    Serial.begin (9600);
void loop () {
    interruptores ();
void RGB_5 (int r5_value, int g5_value, int b5_value)
    analogWrite (led5[0], r5_value);
    analogWrite (led5[1], g5_value);
    analogWrite (led5[2], b5_value);
void interruptores ()
    static int countLst = 0;
    if (countLst != countInt)  {
        countLst = countInt;
        Serial.println (countInt);
    byte bits = 0;
        bits |= (digitalRead (portInt[i]) == ON) << i;
    if (0 == bits)
        countInt = 0;
    switch (countInt)  {
    case 0:
        if (0x02 == bits)
            countInt ++;
    case 1:
        if (0x06 == bits)
            countInt ++;
    case 2:
        if (0x07 == bits)
            countInt ++;
#if 0
    char s [20];
    sprintf (s, " bits %02x, count  %d", bits, countInt);
    Serial.println (s);
#endif
    digitalWrite (led5[0], 3 == countInt ? ON : OFF);
