Hey,
So I've bought some DIN Relays (see note 1 and 2) but they require 12v to switch. My goal was to switch the relay with an Arduino so I've bought an external 12v power supply and some transistors (c557b). The only problem is that I've bought the wrong transistors because they require 6v to switch so I can't switch the transistors as there's 5v on the IO pins. I'm wondering if there's a solution to switch the current relay and transistor without buying new transistors.
Parts I currently have which I can use:
- c557b transistor
- 470K, 220omh and some other resistors
- capacitors
- BT136/500 triac
- opAmp IC
- MOC3021 optocoupler
- arduino's
- And some other parts
Thank you,
Pascal
Note 1: https://www.vekto.nl/nl/relais-1xwissel-12a-24vdc.html
Note 2: https://www.vekto.nl/nl/dinrail-voet-1xwissel.html
