Switch between MPU 6050 and BT06 to control servos
I have two codes that work separately, but how do you get them to switch? I want the servo to use MPU6050 signals when BT06 is disconnected. I have attached the two codes i use.
#include <Wire.h>
#include <MPU6050.h>
#include <Servo.h>
Servo myservo; // servo name
Servo sg90;
Servo sg90two;
int servo_pin = 3;
int servo_pin1 = 5;
MPU6050 sensor ;
int16_t ax, ay, az ;
int16_t gx, gy, gz ;
void setup ( ){
sg90.attach ( servo_pin );
sg90two.attach ( servo_pin1 );
Wire.begin ( );
Serial.begin  (9600);
Serial.println  ( "Initializing the sensor" );
sensor.initialize ( );
Serial.println (sensor.testConnection ( ) ? "Successfully Connected" : "Connection failed");
delay (1000);
Serial.println ( "Taking Values from the sensor" );
delay (200);
void loop ( )
sensor.getMotion6 (&ax, &ay, &az, &gx, &gy, &gz);
ax = map (ax, -15000, 7500, 0, 180) ;
ay = map (ay, -17000, 17000, 0, 180) ;
Serial.println (ax);
sg90.write (ax);
sg90two.write (180-ax);
delay (1000);
#include <SoftwareSerial.h> // TX RX software library for bluetooth
#include <Servo.h> // servo library
Servo myservo1; // servo name
int bluetoothTx = 10; // bluetooth tx to 10 pin
int bluetoothRx = 11; // bluetooth rx to 11 pin
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
  myservo.attach(3); // attach servo signal wire to pin 3
  myservo1.attach(5); // attach servo signal wire to pin 5
  //Setup usb serial connection to computer
  //Setup Bluetooth serial connection to android
  bluetooth.begin(9600);
  //Read from bluetooth and write to usb serial
  if(bluetooth.available()> 0 ) // receive number from bluetooth
    int servopos = bluetooth.read(); // save the received number to servopos
    Serial.println(servopos); // serial print servopos current number received from bluetooth
    myservo.write(servopos); // roate the servo the angle received from the android app
    myservo1.write(180-servopos); // roate the servo the angle received from the android app
Use millis() to measure the time nothing comes from the BT06.
Set a startTime in setup. Then compare millis() and startTime. Decide the time to wait for data, aliveTime. Your descision how much.
When data are available set startTime to a new value, the current millis() value.
Also set a flag by06Available = true. (Start setting it to false in setup)
Can you help me with a code this is my first project?
