I got the first part sorted. Here is the next problem. Firstly I dont want to change what I have got. Yes, it could be done differently but it is fine how it is!!!
when I switch from one case to another the previous case stays active i.e case 1 lights led 1 etc (only six cases drive an output) press any other case and case 1 stays on. I need it to go off. Even the cases without outputs need to switch any outputs off.
hope this is clear.
Last thing, I really need it to be simple. I am NOT a programmer.
Ta
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
float sensorValue = 0;
pinMode(6, INPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(9, INPUT);
pinMode(53, OUTPUT);
pinMode(51, OUTPUT);
pinMode(49, OUTPUT);
pinMode(47, OUTPUT);
pinMode(45, OUTPUT);
pinMode(43, OUTPUT);
//lcd.begin(16, 2);
// lcd.print(" Hello your on");
//lcd.setCursor(0, 1);
int buttonState6 = digitalRead(6);
int buttonState7 = digitalRead(7);
int buttonState8 = digitalRead(8);
int buttonState9 = digitalRead(9);
static int oldbuttonState = -1;
delay(10); // delay in between reads for stability
int buttonState = buttonState6 + buttonState7 * 2 + buttonState8 * 4 + buttonState9 * 8;
static boolean tuneaerial = false;
switch (oldbuttonState)
if (oldbuttonState != buttonState) {
Serial.println(buttonState);
digitalWrite(10, LOW);
switch (buttonState)
case 0:
lcd.clear();
lcd.print("Connect Radio Connect Radio ");
case 1:
// code to display sequence 1 on lcd
lcd.clear();
lcd.print("160 Meters");
digitalWrite(53, HIGH);
case 2:
// code to display sequence 2 on lcd
lcd.clear();
lcd.print("80 Meters ");
digitalWrite(51, HIGH);
case 3:
// code to display sequence 4 on lcd
lcd.clear();
lcd.print("40 Meters ");
digitalWrite(49, HIGH);
case 4:
// code to display sequence 5 on lcd
lcd.clear();
lcd.print("30 Meters");
case 5:
// code to display sequence 6 on lcd
lcd.clear();
lcd.print("20 Meters ");
digitalWrite(47, HIGH);
case 6:
// code to display sequence 7 on lcd
lcd.clear();
lcd.print("17 Meters ");
case 7:
// code to display sequence 8 on lcd
lcd.clear();
lcd.print("15 Meters ");
digitalWrite(45, HIGH);
case 8:
// code to display sequence 9 on lcd
lcd.clear();
lcd.print("12 Meters ");
case 9:
lcd.clear();
lcd.print("10 Meters ");
digitalWrite(43, HIGH);
oldbuttonState = buttonState;
