Switch(case) and MIDI
Dear people,
I’ve got a problem using the MIDI-library in conjunction with the switch-command.
What I’d like to do is, filtering out the velocity of a note and forward it to an LED which is just turned on / off.
Here is my code so far:
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
void setup(){
  MIDI.begin(MIDI_CHANNEL_OMNI);
  MIDI.setHandleNoteOn(Note);
  digitalWrite(13,LOW);
  MIDI.read();
void Note(byte channel, byte note, byte velocity) {
  switch (velocity) {
    case 5:
      digitalWrite(13,HIGH);
    case 10:
So in theory the pin 13 should be high when receiving whatever note with velocity 5 and low when receiving a velocity of 10. But it’s not working.
I tried it with this code:
#include <MIDI.h>
void setup(){
  MIDI.read();
  switch (note) {
    case 60:
    case 61:
And that’s working! So… what I’m missing?
Any help on this?
Thanks,
Chris
You might want to add a Serial.println to that handler to see if it actually gets called and
if so what parameters are passed to it - you assume it will get velocity=5 or 10, but
assumptions may be wrong.
(If the handler happens to be called in an interrupt that won't work though)
  switch (note) {
You are looking at the note value, not the velocity. There is absolutely no reference to 5 or 10 in your code.
And unless you have a way of specifically controlling the velocity, using a switch to look for 5 or 10 is probably not going to work either.
Pete
There are two versions of the code, its the first one that refers to 5 and 10
MarkT:
The problem is, that the serial monitor doesn't support the baudrate of a MIDI... so I println or serial.print won't work here...
Thanks MarkT. I managed to misread the whole thing!.
If you are generating those notes by pressing a note on a keyboard, what are the odds that the velocity will be either exactly 5 or exactly 10?
In the version which uses switch(velocity) remove the entire switch statement and try this instead:
    if(velocity > 30)digitalWrite(13,HIGH);
    else digitalWrite(13,LOW);
I picked 30 almost at random. You can try it with other values.
Pete
Dear Pete,
that works!
Okay guys… I don’t know why… but now my code posted in the first post works perfectly…
Strange…
Thanks anyway! If there are any problems again I’ll let you know!
