We have made a simple sketch to use a keypad with a switch case statement to output a message on the COM port monitor. Below is the code:
#include <Keypad.h>
const byte ROWS = 4; //Four rows
const byte COLS = 4; //Four columns
char keys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {13, 12, 11, 10}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {9, 8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
pinMode(4, INPUT); // Pin 4 set as an input
char key = keypad.getKey();
switch (key) {
case '9':
if (digitalRead(4) == HIGH) {
Serial.println("ON");
else {
Serial.println("OFF");
To toggle Pin 4 HIGH to LOW, we use a wire to go between the GND pin and 3.3V, which seems to work fine. The question is how to change the sketch so that it automatically updates the ON/OFF state once we enter the case statement?
In other words, in order for the state to change, we have to swap to either GND or 3.3V THEN press keypad number 9 to see the update on the COM port monitor. We would like it to automatically update after we initially press 8 for the first time. This will be placed in an LCD menu screen later on and has to automatically update.
If you condition the switch state with some change-of-state code ( In the IDE: File-examples-digital- state change detection ) it'll reset to false 'automatically'. That is, when the switch is actuated you'll get one pass through the code with a (boolean) signal you might call 'switchWasPressed' being true. Do everything you need to do for a switch closure and next time through switchWasPressed will be false.
you connect power to the microcontroller
You press the "8"-key for the very first time and only after this first "press-key-"8"
the automatic updating shall work?
The updating itself is:
if IO-pin 4 detects HIGH update to messageto to be "ON"
if IO-pin 4 detects LOW update to message to be "OFF"
As long as you try to save time by posting too short worded descriptions all that happens is that proceeding in your project needs more time because another round of asking back is played.
Guix's response was spot on. I've provided the code and answered your previous question of "which case" statement. Surely this isn't rocket science to understand and I believe you should refrain from responding if you have nothing of value to comment.
Restating with "more detail":
My son and I are creating a project where we plan on using a 4x20 character LCD and a keypad to display things in different menus. One of those menus will be selected using key 9. Once key 9 is pressed, the LCD will switch to a screen that has the statuses of multiple LEDs, as mentioned in my other reply. When we toggle these LEDs on and off, their states need to update on the LCD menu as they change. The user should only have to press the "9" key ONCE to get into the LCD menu and see the LEDs displayed as being ON or OFF as we toggle the Pins from HIGH to LOW.
I hope you do not connect GND and 3.3V by a wire like you wrote...
Is it correct that you connect pin 4 by wire to 3.3V or GND?
If yes, there is more simple way to achieve this:
pinMode(4,INPUT_PULLUP);
This activates an internal pull-up resistor which keeps the input HIGH. To switch to LOW you can use a switch or button that connects pin 4 to GND.
It also makes sure that you always have a defined signal at pin 4.
There is still the issue of "bouncing" where the status of the pin may toggle several times between high and low due to the mechanical behavior of usual switches/ buttons. That may lead to unexpected behavior of the software as microcontrollers are damned quick. So within micro or at least milliseconds states may change several (ten, twenty, thirty?) times. I would suggest to google for "debouncing Arduino".
Thank you for the insight! Yes, for testing purposes, we currently have a wire connected to pin 4 and we insert the other end into GND or 3.3V to see the state change, but we will try this in the future!
Making a common project with your son is a great thing to have fun, gain experience and spend some interesting time in a useful way!
Glad if my post was of assistance!
What you probably might find also useful as a basis for your sketch is something called "state machine". It takes a little time to get behind its idea, but is key to a lot of otherwise complex designs.
There is a comprehensive example available at Wokwi which I wrote some time ago:
Currently, we are having trouble getting a working menu structure made with what we have. I don't believe the "LiquidCrystal" library is compatible with the LCD we are using, as it has a US2066 driver, but once we sort this out we will definitely give it a shot!
I installed the US2066-library and tried to compile it for Arduino Uno.
This US2066-library uses direct port-manipulation specific to the Ardunio-Mega
This results in compiler-errors for the arduino uno.
I guess you don't want to run up the learning-curve for becoming an LCD-driverchip specialist.
Then there are three options:
asking in the arduino-forum for support in adapting the US2066-driver-library to the Arduino Uno
buying a LCD that has a much more popular driver-chip with Arduino-Uno-compatible drivers
buying an Arduino Mega to be able to use the US2066-driver LCD
Thank you for the research. We may just use this US2066 LCD in 8-bit parallel mode and use their code as a reference. It looks really nice, probably since it has OLEDs. The one issue then would be implementing the call-functions to update the menus when a condition is set. Could get clunky, but we'll see
