Switch case dc motor
Hello everbody, i'm trying to control my dc motor with the "switch case" because how we know it, it's imposible to control the motor position w/out an enconder. how i'll not use it i tried to use the switch case how y'll see bellow:
// sets the pins as outputs:
pinMode(motor1Pin1, OUTPUT);
pinMode(motor1Pin2, OUTPUT);
pinMode(enable1Pin, OUTPUT);
if (Serial.available() > 0) {
int comando = Serial.read();
switch (comando) {
case'1':
Serial.println("Abrir");
digitalWrite(motor1Pin1, HIGH);
digitalWrite(motor1Pin2, LOW);
case'2':
Serial.println("Fechar");
digitalWrite(motor1Pin1, LOW);
digitalWrite(motor1Pin2, HIGH);
but even if i use this, the dc motor dont stop when i want...after a time that i decided "(1000)".
like this /
the dc motor start and stop, in a time that i want
// Motor A
int motor1Pin1 = 27;
int motor1Pin2 = 26;
int enable1Pin = 14;
const int freq = 1500;
const int pwmChannel = 0;
const int resolution = 8;
int dutyCycle = 200;
char a;
char b;
void Setup() {
char comando=Serial.read();
Serial.println(comando);
delay(2000);
switch (comando) {
case 'a':
case 'b':
Hi, @ykinifi
To add code please click this link;
Can you please post a schematic of your project?
Can you please tell us what model Arduino are you using?
What motor you are controlling?
What are you using as a motor driver?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Your topic has been moved to a more suitable location on the forum. Introductory Tutorials is for tutorials that e.g. you write, not for questions. Feel free to write a tutorial once you have solved your problem :wink:
Try changing the variable you read into to a char.
  char comando = Serial.read();
hello tom!!! i hope you're going well.
this project is for a window, a mini window...that's why i'm using the dc motor, because the micro servo motor 9g can just reach 180º...how this window is a little big i decided to use a dc motor...
my microcontroller is an esp wrover and i'm using a ln289 driver...the h-brigde.
my all code is bellow /
// Motor A
char a;
char b;
void Setup() {
delay(2000);
switch (comando) {
case 'a':
case 'b':
tks bro, i'm joing in this world yet LOL.
i'm sorry xD
"Setup" needs to be "setup" for code to compile
looks like you have one motor. pins 1&2 control direction and enable speed.
don't see pin 14 being a PWM pin on any Arduino (see analogWrite())
consider that uses 'f' for forward, 'r' for reverse and anything else stop
// Pin1/2 control direction, enablePin controls speed
int enablePin = 14;
void setup ()
    Serial.begin (9600);
    pinMode (motor1Pin1, OUTPUT);
    pinMode (motor1Pin2, OUTPUT);
    pinMode (enablePin,  OUTPUT);
void loop ()
    if (Serial.available ())  {
        char comando=Serial.read ();
        Serial.println (comando);
        switch (comando) {
        case 'r':       // reverse
            digitalWrite (motor1Pin1, HIGH);
            digitalWrite (motor1Pin2, LOW);
            digitalWrite (enablePin, HIGH);
        case 'f':       // forward
            digitalWrite (motor1Pin1, LOW);
            digitalWrite (motor1Pin2, HIGH);
        default:        // stop
            digitalWrite (enablePin, LOW);
tks for helping bro!
but the problem has been the dc motor dont breaking after the time that i want, this is why i thought that using delay the dc motor would start after my command, and break after a time...maybe 1 sec after
In case you missed it.
why couldn't i use this one?
The ESP32 has an internal module called the MCWPM,
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/mcpwm.html
that can interface with the ln289.
#include "driver/mcpwm.h"
voiding setup()
  mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1A, GPIO_NUM_4 ); // Azimuth
  mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_NUM_12 ); // Altitude servo
  mcpwm_config_t pwm_config = {};
  pwm_config.frequency = 50;    //frequency = 50Hz, i.e. for every servo motor time period should be 20ms
  pwm_config.cmpr_a = 0;    //duty cycle of PWMxA = 0
  pwm_config.cmpr_b = 0;    //duty cycle of PWMxb = 0
  pwm_config.counter_mode = MCPWM_UP_COUNTER;
  pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
  log_i( "MCPWM complete" );
  mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config);    //Configure PWM0A timer 0 with above settings
  mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_1, &pwm_config);    //Configure PWM0A timer 1 with above settings
  fMoveAltitude( 1525 );
  fMoveAzimuth( 1500 );
void fMoveAltitude( int MoveTo )
  mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, MoveTo);
  vTaskDelay( 12 );
void fMoveAzimuth( int MoveTo )
  mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_OPR_A, MoveTo);
  vTaskDelay( 12 );
A code snippet of using the MCPWM under with the Arduino IDE.
Good luck.
i need to be honest, i'm not undertandig why i would use this, because my code worked, the only problem is that i cant make my dc motor break when i want...even just when i use other switch case in te monitor. got it?
i'm sorry, i didnt got what u say
The return type of Serial.read() is int, int16_t.
A char will not hold all the possible return values.
Assigning it to a char will not make a difference in comparisons to character literals like '1'. No difference in the switch/case.
'1' is 49 or 0x31, the same number Serial.read() returns when the next character is '1'.
a7
Yep agreed... fair point.
No worries.
Now please edit your post #5, select all code and click the </> button to apply so-called code tags and next save your post. It makes it easier to read, easier to copy and prevents the forum software will display it correctly.
you set a pin HIGH but never attempt to undo that after a second by setting the pin LOW
