Hi! Can you please help me with my code? I am creating simple weather station and I have 20x4 liquid crystal LCD display where I created pages that are changing, but I have no idea how to increase time between the pages. I was trying with delay but it broke my program and when I tried millis() it done nothing. I am new to arduino so any help appreciated. Thanks..
This is my program for switching case:
// LCD pages
switch(strana){
case 1:
lcd.clear();
// Reading pressure
float pressure = bmp280.readPressure();
sprintf(text, "%u.%02u hPa ", (int)(pressure/100), (int)((uint32_t)pressure % 100));
lcd.setCursor(0, 1);
lcd.print("Pressure:");
lcd.setCursor(9,1);
lcd.print(text);
// Reading altitude
float altitude_ = bmp280.readAltitude(1013.25); // get altitude (this should be adjusted to your local forecast
sprintf(text, "%u.%02u m ", (int)altitude_, (int)(altitude_ * 100)%100, 223);
lcd.setCursor(0,0);
lcd.print("Altitude:");
lcd.setCursor(10,0);
lcd.print(text);
lcd.setCursor(0,3);
lcd.print("Date:");
lcd.setCursor(6,3);
lcd.print(String(displayday)+"/"+String(displaymonth)+"/"+String(displayyear));
lcd.setCursor(0,2);
lcd.print("Mp:");
lcd.setCursor(4,2);
lcd.print(moonphase);
if(millis() >= time_now + period){
time_now += period;
strana = 1 ;
case 2:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Temp.In:");
lcd.setCursor(8,0);
lcd.print(tem1);
lcd.setCursor(14,0);
lcd.print((char)223 );
lcd.setCursor(15,0);
lcd.print("C" );
lcd.setCursor(0,1);
lcd.print("Humid.In:");
lcd.setCursor(9,1);
lcd.print(hum1);
lcd.setCursor(13,1);
lcd.print("%");
lcd.setCursor(0,2);
lcd.print("Temp.Out:");
lcd.setCursor(9,2);
lcd.print(tem2);
lcd.setCursor(15,2);
lcd.setCursor(16,2);
lcd.print("C" );
lcd.setCursor(0,3);
lcd.print("Humid.Out:");
lcd.setCursor(10,3);
lcd.print(hum2);
lcd.setCursor(16,3);
lcd.print("%");
time_now += period;
strana = 2 ;
Serial.print("Approx Altitude = ");
Serial.print(altitude_);
Serial.println(" m");
There is whole code:
//--------------------------------[ Libraries ]---------------------------------->
#include <Adafruit_BMP280.h>
#include "Wire.h"
#include "LCD.h"
#include "LiquidCrystal_I2C.h"
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DS3231.h>
#include "RTClib.h"
#include <TM1637Display.h>
//--------------------------------[ Variables ]---------------------------------->
#define DHTPIN1 13
#define DHTTYPE1 DHT22
#define DHTPIN2 12
#define DHTTYPE2 DHT11
#define CLK 10
#define DIO 11
char text[14];
String moonphase ;
int cas = 0;
int teplota = 0;
int tlak = 0;
int vlhkost = 0;
int strana = 1 ;
int period = 5000;
unsigned long time_now = 0;
byte count = 0;
boolean PAGE1 = false;
boolean PAGE2 = false;
// Display I2C adress
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7);
// Define device I2C address: 0x76 or 0x77
#define BMP280_I2C_ADDRESS 0x76
Adafruit_BMP280 bmp280;
//--------------------------------[ Initializing sensors ]---------------------------------->
// Initialize DHT sensor
DHT dht1 = DHT(DHTPIN1, DHTTYPE1);
DHT dht2 = DHT(DHTPIN2, DHTTYPE2);
// Create rtc and display object
RTC_DS3231 rtc;
TM1637Display display = TM1637Display(CLK, DIO);
//--------------------------------[ Void setup ]---------------------------------->
void setup(){
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
// Initializing RTC
rtc.begin();
// Setting up what time is on display
if (rtc.lostPower()) {
Serial.println("RTC lost power, lets set the time!");
// Following line sets the RTC to the date & time this sketch was compiled:
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// Set the TM1637 display brightness (0-7):
display.setBrightness(7);
// Clear the display:
display.clear();
// Check if all components are working correctly
Serial.println(F("Arduino + BMP280"));
if (!bmp280.begin(BMP280_I2C_ADDRESS))
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1);
// Initializing DHT sensors
dht1.begin();
dht2.begin();
// Set off LCD module
lcd.begin (20,4);
lcd.setBacklightPin(3,POSITIVE);
lcd.setBacklight(HIGH);
// Writing "Weather Station" onto the LCD
lcd.setCursor(3,0);
lcd.print("Weather Station");
//--------------------------------[void loop]--------------------------------->
void loop(){
// Getting time from real time clock
DateTime now = rtc.now();
// Create time format to display
int displaytime = (now.hour() * 100) + now.minute();
int displayday = now.day();
int displaymonth = now.month();
int displayyear = now.year();
// Display the current time in 24 hour format
display.showNumberDecEx(displaytime, 0b11100000, true);
// Blinking center dots
// Prints displaytime without center colon
display.showNumberDec(displaytime, true);
// Read the humidity in %
float hum1 = dht1.readHumidity();
float hum2 = dht2.readHumidity();
// Read the temperature as Celsius
float tem1 = dht1.readTemperature();
float tem2 = dht2.readTemperature();
// Read the temperature as Fahrenheit
float f = dht1.readTemperature(true);
// Check if any reads failed and exit early (to try again):
if (isnan(hum1) || isnan(tem1) || isnan(f)) {
Serial.println("Failed to read from DHT sensor!");
return;
// Compute heat index in Fahrenheit (default)
float hif = dht1.computeHeatIndex(f, hum1);
// Compute heat index in Celsius
float hic = dht1.computeHeatIndex(tem1, hum1, false);
// Printing measured units onto the Serial Monitor
Serial.print("Hum1: ");
Serial.print(hum1);
Serial.print(" Hum2: ");
Serial.print(hum2);
Serial.print(" % ");
Serial.print("Tem1: ");
Serial.print(tem1);
Serial.print(" Tem2: ");
Serial.print(tem2);
Serial.print(" \xC2\xB0");
Serial.print("C | ");
Serial.print(f);
Serial.print("F ");
Serial.print("Heat index: ");
Serial.print(hic);
Serial.print(hif);
Serial.println("F");
// Moonphase - MP
int led[]={2,3,4,5,6,7,8,9} ;
int Y = now.year();
int M = now.month();
int D = now.day();
int A = Y/100;
int B = A/4;
int C = 2-A+B;
float E = 365.25 * (Y+4716);
float F = 30.6001 * (M+1) ;
float JD = C+D+E+F-1524.5 ;
float dsn = JD - 2451549.5;
float nm = dsn / 29.53;
float fnm = nm-long(nm);
float Mooncyc = fnm*29.5;
if(Mooncyc >= 0 && Mooncyc < 3.27777778 ){moonphase = ("New moon");
for(int i = 0 ;i< 8; i++ ){if (i == 0 ){digitalWrite(led[i],HIGH);}
else{digitalWrite(led[i],LOW);}
else if(Mooncyc >= 3.27777778 && Mooncyc < 6.55555556 ){moonphase = "Wax cresc";
for(int i = 0 ;i< 8; i++ ){if (i == 1 ){digitalWrite(led[i],HIGH);}
else if(Mooncyc >= 6.55555556 && Mooncyc < 9.83333334 ){moonphase = ("1st");
for(int i = 0 ;i< 8; i++ ){if (i == 2 ){digitalWrite(led[i],HIGH);}
else if(Mooncyc >= 9.83333334 && Mooncyc < 13.1111111 ){moonphase = ("Waxing gib");
for(int i = 0 ;i< 8; i++ ){if (i == 3 ){digitalWrite(led[i],HIGH);}
else if(Mooncyc >= 13.1111111 && Mooncyc < 16.3888889 ){moonphase = ("Full");
for(int i = 0 ;i< 8; i++ ){if (i == 4 ){digitalWrite(led[i],HIGH);}
else if(Mooncyc >= 16.3888889 && Mooncyc < 19.6666667 ){moonphase = ("Waning gib");
for(int i = 0 ;i< 8; i++ ){if (i == 5 ){digitalWrite(led[i],HIGH);}
else if(Mooncyc >= 19.6666667 && Mooncyc < 22.9444445 ){moonphase = ("3rd");
for(int i = 0 ;i< 8; i++ ){if (i == 6 ){digitalWrite(led[i],HIGH);}
else if(Mooncyc >=22.9444445 && Mooncyc < 26.2222223 ){moonphase = "Waning cresc";
for(int i = 0 ;i< 8; i++ ){if (i == 7 ){digitalWrite(led[i],HIGH);}
else if(Mooncyc >= 26.2222223 && Mooncyc < 29.5 ){moonphase = "Nov";
// LCD pages
switch(strana){
case 1:
lcd.clear();
// Reading pressure
lcd.setCursor(9,1);
lcd.print(text);
// Reading altitude
lcd.setCursor(0,0);
lcd.print(text);
lcd.setCursor(0,3);
lcd.print("Date:");
lcd.setCursor(6,3);
lcd.setCursor(0,2);
lcd.print("Mp:");
lcd.setCursor(4,2);
time_now += period;
strana = 1 ;
case 2:
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(8,0);
lcd.print(tem1);
lcd.print("C" );
lcd.setCursor(0,1);
lcd.setCursor(9,1);
lcd.print(hum1);
lcd.print("%");
lcd.setCursor(0,2);
lcd.setCursor(9,2);
lcd.print(tem2);
lcd.print("C" );
lcd.setCursor(0,3);
lcd.print(hum2);
lcd.print("%");
time_now += period;
strana = 2 ;
3
And there is scheme:
