Switch case does not output accurately
ok, so i have my grand trans code that does everything but no first gear on the physical transmission. i have a basic code to run the same case block and it gets first gear output from the transmission. i dont get what could be different?
#include <SPI.h>
#include <mcp_can.h>
MCP_CAN CAN0(53);  // CS pin for MCP2515
// Variables to store data from CAN message
int MAP = 0;   // Manifold Air Pressure (kPa)
int RPM = 0;   // Engine RPM
int CLT = 0;   // Coolant Temperature (deg F)
int TPS = 0;   // Throttle Position (%)
const int pin45 = 45;               // Pin for TPS indicator
unsigned long previousMillis = 0;   // Store last time pin 45 state changed
const long interval = 500;          // Blink interval (500 milliseconds)
bool pin45State = LOW;              // Keep track of the state of pin 45
bool initialized = false;  // Add this globally to track initialization state
// transmission info
const int reverse_pin =    A0;  // Pin for reverse switch
const int drive_pin =      A1;  // Pin for drive switch
const int shiftdown_pin =  A2;  // Pin for shiftdown switch
const int shiftdown2_pin = A3;  // Pin for second shiftdown switch
const int shiftup_pin =    A4;  // Pin for shiftup switch
const int shiftup2_pin =   A5;  // Pin for second shiftup switch
const int A_clutch = 2;  // PWM output for Solenoid 1
const int B_clutch = 3;  // PWM output for Solenoid 2
const int C_clutch = 4;  // PWM output for Solenoid 3
const int EDS4     = 5;  // PWM output for Solenoid 4
const int MV1     =  6;  // Digital output for MV1 solenoid
const int PSI     = 11;  // PWM output for Pressure Solenoid
const int A_grab = 255;
const int A_free = 0;
const int A_slip = 70;
const int B_grab = 0;
const int B_free = 255;
const int B_slip = 55;
const int C_grab = 255;
const int C_free = 0;
const int C_slip = 55;
const int D_grab = 0;
const int D_free = 255;
const int D_slip = 55;
const int E_grab = 0;
const int E_free = 255;
const int E_slip = 70;
const int D_clutch = LOW;       // MV1 condition for multi valve
const int E_clutch = HIGH;
int counter = 1;             // Current gear
int prevCounter = 1;         // Previous gear
int lastDriveGear = 1;       // To remember the last gear in Drive mode
bool inPark = false;            // Indicates if the vehicle is in park mode
bool inReverse = false;         // Indicates if the vehicle is in reverse mode
bool inDrive = false;           // Indicates if the vehicle is in drive mode
bool canShiftDown = true; // Flag to control downshifting
bool canShiftUp = true;   // Flag to control upshifting
void handleShiftdown() {
  if (digitalRead(shiftdown_pin) == LOW && digitalRead(shiftdown2_pin) == HIGH && canShiftDown) {
    canShiftDown = false;
    counter--;
    if (counter < 1) {
      counter = 1;        // Ensure gear doesn't go below 1st
    Serial.print(" Down Shifted into ");
  } else if (digitalRead(shiftdown_pin) == HIGH && digitalRead(shiftdown2_pin) == LOW && !canShiftDown) {
void handleShiftup() {
  if (digitalRead(shiftup_pin) == LOW && digitalRead(shiftup2_pin) == HIGH && canShiftUp) {
    canShiftUp = false;
    counter++;
    if (counter > 6) {
      counter = 6;         // Ensure gear doesn't go above 6th
    Serial.print(" Up Shifted into ");
  } else if (digitalRead(shiftup_pin) == HIGH && digitalRead(shiftup2_pin) == LOW && !canShiftUp) {
    canShiftUp = true;
// VVT and TCC code
const int  TCC = 7;
const byte VVT1 = 8;
const byte VVT2 = 9;
bool TCCEnabled = false;     // Track the state of TCC
bool TCCEngaged = false;      // true if engaged, false if not
int pwmValue = 0;
const int fadeStartRPM = 2600;  // RPM threshold to start the fade
const int fadeStopRPM = 1500;   // RPM threshold to stop the fade and turn off
// Idle Range
const int idleRangeRPMMin =  1300;  // Minimum RPM for the idle range
const int idleRangeRPMMax =  1800;  // Maximum RPM for the idle range
const int idleRangeStartPWM = 200;  // Start PWM percentage for the idle range
const int idleRangeEndPWM =   255;  // End PWM percentage for the idle range
// Torque Range
const int torqueRangeRPMMin =  1800;   // Minimum RPM for the torque range
const int torqueRangeRPMMax =  4000;   // Maximum RPM for the torque range
const int torqueRangeStartPWM = 255;  // Start PWM percentage for the torque range
const int torqueRangeEndPWM =   255;    // End PWM percentage for the torque range
// Peak Range
const int peakRangeRPMMin = 4000;   // Minimum RPM for the peak range
const int peakRangeRPMMax = 5500;   // Maximum RPM for the peak range
const int peakRangeStartPWM = 0;  // Start PWM percentage for the peak range
const int peakRangeEndPWM = 0;      // End PWM percentage for the peak range
void fadeEDS4();
void startTCC();
void stopTCC();
void fadeTCC(int startValue, int endValue, int duration);
  // Set pin modes
  pinMode(reverse_pin, INPUT_PULLUP);
  pinMode(drive_pin, INPUT_PULLUP);
  pinMode(shiftdown_pin, INPUT_PULLUP);
  pinMode(shiftdown2_pin, INPUT_PULLUP);
  pinMode(shiftup_pin, INPUT_PULLUP);
  pinMode(shiftup2_pin, INPUT_PULLUP);
  pinMode(A_clutch, OUTPUT);
  pinMode(B_clutch, OUTPUT);
  pinMode(C_clutch, OUTPUT);
  pinMode(EDS4,     OUTPUT);
  pinMode(PSI,      OUTPUT);
  pinMode(MV1,      OUTPUT);
  pinMode(TCC,      OUTPUT);
  pinMode(pin45,    OUTPUT);  // RPM indicator
  pinMode(10, OUTPUT);
  pinMode(VVT1, OUTPUT);
  pinMode(VVT2, OUTPUT);
  stopTCC();    // Make sure TCC is off initially
  // Initialize MCP2515 CAN interface at 500 kbps with 8 MHz crystal
  if (CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK) {
    Serial.println("Arduino CAN BUS is good!");
  // Set MCP2515 to normal mode to receive messages
  CAN0.setMode(MCP_NORMAL);
  long unsigned int rxId;
  unsigned char len = 0;
  unsigned char buf[8];
  // Read message from CAN bus
  if (CAN0.readMsgBuf(&rxId, &len, buf) == CAN_OK) {
    // Check if the received message ID matches the Dash Broadcasting ID (0x5E8)
    if (rxId == 0x5E8) {
      //Serial.println("Received Dash Broadcasting message:");
      // Extract values from the data buffer (big-endian format)
      // MAP (Manifold Air Pressure) in kPa, stored in bytes 0 and 1
      MAP = (buf[0] << 8) | buf[1];  // Big-endian: MSB first
      MAP /= 10;  // Divide by 10 according to the data format (multiply/divide info)
      // RPM (Engine RPM), stored in bytes 2 and 3
      RPM = (buf[2] << 8) | buf[3];  // No scaling needed
      // CLT (Coolant Temperature) in degrees Fahrenheit, stored in bytes 4 and 5
      CLT = (buf[4] << 8) | buf[5];
      CLT /= 10;  // Divide by 10 to get temperature in degrees
      // TPS (Throttle Position) as a percentage, stored in bytes 6 and 7
      TPS = (buf[6] << 8) | buf[7];
      TPS /= 10;  // Divide by 10 to get percentage
      // Print the extracted values to the Serial Monitor
      /*  Serial.print("MAP: ");
        Serial.print(MAP);
        Serial.print(" kPa, ");
        Serial.print("RPM: ");
        Serial.print(RPM);
        Serial.print(", ");
        Serial.print("CLT: ");
        Serial.print(CLT);
        Serial.print(" deg F, ");
        Serial.print("TPS: ");
        Serial.print(TPS);
        Serial.println(" %");
      int mappedPSI;
      if (TPS > 70) {
        mappedPSI = 0;   // Set PSI to 0 if TPS is above 70%
        mappedPSI = map(TPS, -10, 70, 255, 0);  // Map TPS to PSI 255-0
      analogWrite(PSI, mappedPSI);  // Set the PSI output based on the mapped or overridden value
      // Control pin 45 based on RPM
      unsigned long currentMillis = millis();  // Get the current time
      if (RPM < 50) {                                            // CAN BUS Warning led on board
        // Blink pin 45 on and off every 500 milliseconds
        if (currentMillis - previousMillis >= interval) {
          // Save the last time the pin state changed
          // If the output is LOW, turn it HIGH, and vice-versa
          pin45State = !pin45State;
          digitalWrite(pin45, pin45State);
      } else if (RPM > 400) {
        // Keep pin 45 HIGH if RPM is over 400
        digitalWrite(pin45, HIGH);
        // Otherwise, ensure pin 45 is LOW
        digitalWrite(pin45, LOW);
  // Reverse Mode
  if (digitalRead(reverse_pin) == LOW) {  // Check if reverse pin is LOW (indicating reverse)
    if (!inReverse) {                     // Only enter this block if not already in reverse
      inReverse = true;                   // Set the reverse flag
      inPark = false;                     // Exit park mode
      if (inDrive) {                      // If we were in Drive, store the lastDriveGear
        lastDriveGear = counter;
        inDrive = false;
      counter = -1;                       // Set the counter to -1 for reverse
      Serial.println(" Reverse ");
      delay(50);
  } else {                                // If reverse pin is HIGH (not in reverse)
    if (inReverse) {                      // If previously in reverse
      inReverse = false;                  // Exit reverse mode
  // Park Mode ......................................................................................................
  if (digitalRead(reverse_pin) == HIGH && digitalRead(drive_pin) == HIGH) {
    if (!inPark) {
      inPark = true;      // Enter "park" mode
      inReverse = false;  // Exit "reverse" mode
        inDrive = false;
      counter = 0;        // Set counter to 0 for park/neutral
      Serial.println(" Neutral ");
      delay(50);
  // Drive Mode .....................................................................................................
  if (digitalRead(drive_pin) == LOW) {
    if (!inDrive) {         // If we're newly entering Drive mode
      inDrive = true;       // Set drive mode flag
      if (lastDriveGear == 0) {
        lastDriveGear = 1;  // Ensure it starts in first gear if the last drive gear was undefined
      counter = lastDriveGear;  // Restore the last drive gear
      prevCounter = 0;          // Force gear change logic to execute
      Serial.println("Drive");
      delay(50);
    // Handle shifting
    handleShiftdown();
    handleShiftup();
  // Gear changing logic
  if (counter != prevCounter) {
    switch (counter) {
      case -1:
        analogWrite(B_clutch, B_slip);
        analogWrite(EDS4,     D_slip);
        delay (900);
        stopTCC();
        digitalWrite(MV1,   D_clutch);
        analogWrite(A_clutch, A_free);
        analogWrite(B_clutch, B_grab);
        analogWrite(C_clutch, C_free);
        analogWrite(EDS4,     D_grab);
      case 0:
        stopTCC();
        analogWrite(A_clutch, 0);
        analogWrite(B_clutch, 0);
        analogWrite(C_clutch, 0);
        analogWrite(EDS4,     0);
      case 1:
        Serial.println("first gear");
        digitalWrite(MV1, LOW);
        analogWrite(A_clutch, 250);
        analogWrite(B_clutch, 255);
        analogWrite(EDS4, 70);
        Serial.println("80");
        analogWrite(EDS4, 50);
        Serial.println("50");
        Serial.println("0");
      case 2:
        Serial.println(" 2nd gear");
        switch (prevCounter) {
          case 1:
            // analogWrite(C_clutch, C_slip);
            // analogWrite(EDS4,     D_slip);
            Serial.println(" up slip ");
            stopTCC();
            //delay(200);
            analogWrite(A_clutch, 255);
            analogWrite(C_clutch, 255);
            analogWrite(EDS4,     255);
            Serial.println(" up engaged ");
          case 3:
            // analogWrite(B_clutch, B_slip);
            Serial.println(" down slip ");
            stopTCC();
            Serial.println(" down engaged ");
      case 3:
        Serial.println(" 3rd gear");
          case 2:
            Serial.println(" up slip");
            stopTCC();
            delay(150);
            digitalWrite(MV1,   E_clutch);
          case 4:
            stopTCC();
            Serial.println(" easy money!");
      case 4:
        Serial.println(" 4th gear");
          case 3:
            stopTCC();
            Serial.println(" slammin up! ");
            startTCC();
            Serial.println(" TCC enabled");
          case 5:
            stopTCC();
            analogWrite(A_clutch, A_slip);
            delay (200);
            startTCC();
      case 5:
        Serial.println(" 5th gear");
        stopTCC();
        Serial.println(" engaged!");
        startTCC();
      case 6:
        Serial.println(" 6th gear");
        stopTCC();
        startTCC();
    prevCounter = counter;
    delay(25);
  //  VVT and TCC
  // Map the RPM value to the desired PWM range based on the idle range
  if (RPM < idleRangeRPMMin) {
    pwmValue = 0;  // Default PWM value for RPMs below the idle range
  } else if (RPM >= idleRangeRPMMin && RPM <= idleRangeRPMMax) {
    pwmValue = map(RPM, idleRangeRPMMin, idleRangeRPMMax, idleRangeStartPWM, idleRangeEndPWM);
  } else if (RPM >= torqueRangeRPMMin && RPM <= torqueRangeRPMMax) {
    pwmValue = map(RPM, torqueRangeRPMMin, torqueRangeRPMMax, torqueRangeStartPWM, torqueRangeEndPWM);
  } else if (RPM >= peakRangeRPMMin && RPM <= peakRangeRPMMax) {
    pwmValue = map(RPM, peakRangeRPMMin, peakRangeRPMMax, peakRangeStartPWM, peakRangeEndPWM);
  // Set the PWM output
  analogWrite(VVT1, pwmValue);
  analogWrite(VVT2, pwmValue);
  //Serial.println(pwmValue);
  // Check if the RPM is greater than the fade start threshold and TCC is enabled
  if (!TCCEngaged && TCCEnabled && RPM > fadeStartRPM) {
    fadeTCC(0, 255, 1000);             // start, end, time
  // Check if the RPM is below the fade stop threshold
  if (RPM < fadeStopRPM) {
    analogWrite(TCC, 0);             // Turn off the PSI output
    TCCEngaged = false;
// functions
void fadeEDS4(int startValue, int endValue, int duration) {
  int steps = 100;  // Number of steps for the fade
  int delayTime = duration / steps;
  float stepValue = (endValue - startValue) / float(steps);
  for (int i = 0; i <= steps; i++) {
    int value = startValue + (stepValue * i);
    analogWrite(EDS4, value);
    delay(delayTime);
// Handles starting TCC by enabling TCC control
void startTCC() {
  TCCEnabled = true;   // Enable TCC
  TCCEngaged = false;  // TCC disengaged
// Handles stopping TCC by setting it to 0 and disabling TCC control
void stopTCC() {
  analogWrite(TCC, 0); // Immediately set TCC value to 0
  TCCEnabled = false;  // Disable TCC
// Non-blocking fade function for TCC, with a final set to 255 after fade completes
void fadeTCC(int startValue, int endValue, int duration) {
  static int currentStep = 0;
  static unsigned long previousMillis = 0;
  static int steps = 150;  // Number of steps for the fade
  static int delayTime = duration / steps;
  static float stepValue = (endValue - startValue) / float(steps);
  static bool fading = false;
  // Start the fading process if it's not already started
  if (!fading) {
    currentStep = 0;
    previousMillis = millis();
    fading = true;
  // Continue the fading process
  if (fading) {
    if (currentMillis - previousMillis >= delayTime) {
      previousMillis = currentMillis;  // Reset the timer
      int value = startValue + (stepValue * currentStep);
      analogWrite(TCC, value);
      currentStep++;
      // Check if fade is complete
      if (currentStep > steps) {
        fading = false;  // Stop the fading
        TCCEngaged = true;
        analogWrite(TCC, 255); // Ensure TCC stays at 255 after fade completes
const int MV1  = 6;
const int TCC  = 7;
const int VVT1 = 8;
const int VVT2 = 9;
// 1st A/D // 2nd A/C // 3rd A/B // 4th A/E // 5th B/E // 6th C/E
void loop() {                   //  I RUN THE BLOCK ABOVE AND IT FUNCTIONS AND GETS FIRST GEAR. BELOW WONT EVEN RUN THE DELAY AND SET TO 0!  BASTARD
  while (1) {}
Your second code is missing a Serial.begin().
i was just using it with no feedback really. just output the same block and it grabs first gear.
If output is the same and "grabs first gear"... calls to handleShiftdown() makes "counter--" then "if counter < 1"... results in "counter = 1"
    counter--;
    if (counter < 1) {
sorry i might not be explaining this right. so the long code will select first gear fine and run the output block but the trans will not go into first gear. the short code will run and go right into first gear on the transmission. i am about to make a video of the anomaly....
Are the sketches labeled "short" and "long"?
Is the long code good? (will select first gear fine and run the output block)
Is the short code bad? (go right into first gear)
no i was just referring to them here as long and short.
the long one does everything as it should but the block that engages first gear physically in the transmission does not get the gear. if i run the short code it will engage first gear in the transmission. i know it may sound odd or what ever but i have been trying to figure it out for a couple weeks now.
on my driver board it has LED lights and does the sequence identical for both but the short one 100% works and the long on just does not get the gear to work
Your "long code" has many "pinMode" settings to INPUT_PULLUP which hold the pins high. Not setting these pins will allow the pins to float. Maybe the floating pins are effecting the physical by not being tie HIGH. Try adding all the "INPUT_PULLUP" settings to your setup().
