switch case from Serial.read multi character / string?
Guys,
sorry for the title... know its a little vauge...
I have a sample code much like the example code that allows me to control a digital pin based on typing a "a" or "A".... (on/off). The issue I am having is that I would like to control that same pin by typing a combination of 2 characters.... for example. type "a" followed by "A" for HIGH, and "A" followed by "a" for LOW...
I can post code, but its really pretty much at the example stage. Let me know if this is clear enough...
Thanks,
Simple pin control code.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if(readString.indexOf("on") >=0)
      digitalWrite(ledPin, HIGH);
    if(readString.indexOf("off") >=0)
      digitalWrite(ledPin, LOW);
    readString="";
zoomkat,
Thanks for the quick reply. I apologize because I may have simplified what I am looking to do a little too much....
I need to control various pins on a mega, (20 to be exact) and was using switch case based on what character i typed on the keyboard to control the 20 pins...
the question I have is how can I change the single character typed to 2 characters (maybe even followed by enter??)
Let me know if that clarifies... thanks again
sorry. I posted this to the wrong forum. did not mean to double post. won't let me delete it from the other forum. Please let me know if this helps explain what I need....
Hi Guys,
I have a project that I am working on that has 10 shift registers...
The issue I am having is that I need to be able to send characters via serial to turn pins on and off.
the code below is what I have working, but instead of for example, case 'a' or case 'b' I need the unit to wait for more than 1 character before acting. this will enable me to have more than 255 options....
Can someone please help me. not sure what way to go here....
void loop(){
   if (Serial.available() > 0) {
     int inByte = Serial.read();
     // do something different depending on the character received.
     // The switch statement expects single number values for each case;
     // in this example, though, you're using single quotes to tell
     // the controller to get the ASCII value for the character.  For
     // example 'a' = 97, 'b' = 98, and so forth:
     switch (inByte) {
     case 'a':
      setRegisterPin(0, HIGH);
      writeRegisters();
     case 'b':
      setRegisterPin(1, HIGH);
      writeRegisters();
the below will not compile... but here is what I would like for example....
void loop(){
     // in this exmaple, though, you're using single quotes to tell
     switch (inByte) {
     case '!0301':
      writeRegisters();
     case '!0401':
      setRegisterPin(0, LOW);
      writeRegisters();
     case '!0302':
      writeRegisters();
     case '!0402':
      setRegisterPin(1, LOW);
      writeRegisters();
Remove message
