Switch case help
Hello, first time writing here. I have a problem with this “switch case” example. I’ve been trying to modify it in order to accept digital input instead of analog.
So far, I haven’t found a solution.
What I want to do is: If digital input 3 is “high” it goes to case 1. If digital input 4 is “high” it goes to case 2. If digital input 5 is “high” it goes to case 3 and so on.
Could you please help me find a solution to this problem?
const int sensorMin = 0;      // sensor minimum, discovered through experiment
const int sensorMax = 600;    // sensor maximum, discovered through experiment
  // initialize serial communication:
  // read the sensor:
  int sensorReading = analogRead(A0);
  // map the sensor range to a range of four options:
  int range = map(sensorReading, sensorMin, sensorMax, 0, 3);
  // do something different depending on the
  // range value:
  switch (range) {
    case 0:    // your hand is on the sensor
      Serial.println("dark");
    case 1:    // your hand is close to the sensor
      Serial.println("dim");
    case 2:    // your hand is a few inches from the sensor
      Serial.println("medium");
    case 3:    // your hand is nowhere near the sensor
      Serial.println("bright");
  delay(1);        // delay in between reads for stability
It is a bit ridiculous to use a switch statement to process an input that can only have one of two states. A simple if-else is far more appropriate.
Regards,
Ray L.
What I want to do is: If digital input 3 is "high" it goes to case 1. If digital input 4 is "high" it goes to case 2. If digital input 5 is "high" it goes to case 3 and so on.
I'm not sure if more than one pin can be high at a time and if you need to respond to multiple situations, but if so, you can make a switch case on the binary values of the combination
Example three switches can have eight states, and you switch case on that value
000 = 0
001 = 1
010 = 2
011 = 3
100 = 4
101 = 5
110 = 6
111 = 7
cattledog:
000 = 0
001 = 1
010 = 2
011 = 3
100 = 4
101 = 5
110 = 6
111 = 7
That’s a good idea, this will also give cases available for more than one input being high at the same time (which, if the inputs are physical switches on a control panel, is a common scenario).
