Switch case? (Hijack)
sir,
I need one pus button comand in my relay program mines push button press the start program delay time.
my code heare
define RELAY1 7 //Defining the pin 7 of the Arduino for the 4 relay module
define RELAY2 6 //Defining the pin 6 of the Arduino for the 4 relay module
define RELAY3 5 //Defining the pin 5 of the Arduino for the 4 relay module
define RELAY4 4 //Defining the pin 4 of the Arduino for the 4 relay module
void setup() { pinMode(RELAY1, OUTPUT); //Defining the pin 7 of the Arduino as output pinMode(RELAY2, OUTPUT); //Defining the pin 6 of the Arduino as output pinMode(RELAY3, OUTPUT); //Defining the pin 5 of the Arduino as output pinMode(RELAY4, OUTPUT); //Defining the pin 4 of the Arduino as output }
void loop() { digitalWrite(RELAY1,LOW); // This will Turn ON the relay 1 delay(5000); // Wait for 5 seconds digitalWrite(RELAY1,HIGH); // This will Turn the Relay off delay(5000); // Wait for 5 seconds
digitalWrite(RELAY2,LOW); // This will Turn ON the relay 2 delay(5000); // Wait for 5 seconds digitalWrite(RELAY2,HIGH); // This will Turn the Relay Off delay(5000); // Wait for 5 seconds
digitalWrite(RELAY3,LOW); // This will Turn ON the relay 3 delay(5000); // Wait for 5 seconds digitalWrite(RELAY3,HIGH); // This will Turn the Relay Off delay(5000); // Wait for 5 seconds
digitalWrite(RELAY4,LOW); // This will Turn ON the relay 4 delay(5000); // Wait for 5 seconds digitalWrite(RELAY4,HIGH); // This will Turn the Relay Off delay(5000); // Wait for 5 seconds
And the pushbutton will do what with the relays?
Add some global variables:
byte currentState;
byte previousState;
byte pusPin = xxx;
in setup(), add:
   pinMode(pusPin, INPUT_PULLUP);
in loop(), add:
   currentState = digitalRead(pusPin);
   if(currentState == LOW)
      // Do nothing, because there are no requirements for when the switch is pressed
      // Do nothing, because there are no requirements for when the switch is not pressed
   if(currentState != previousState)
         // Do nothing, because there are no requirements for when the switch has become pressed
         // Do nothing, because there are no requirements for when the switch has become released
   previousState = currentState;
rksharma: I need one pus button comand in my relay program mines push button press the start program delay time.
That did not translate well. My guess is that you mean:
"I want to add a pushbutton to my sketch. I want the sketch to wait for the button to be pushed before starting a cycle of turning relays on and off."
To add a pushbutton, connect it between an unused pin and Ground.
In setup(), set that pin's pinMode() to INPUT_PULLUP. The pin will read as HIGH unless the button is pressed.
Where you want to wait for a button press, add:
   while (digitalRead(BUTTON_PIN) == HIGH) {/*Do Nothing*/}
