Switch....Case issue
Hello arduino community,
First of all please bare with me as I'm not a software developer.
I'm working on a project where a have a few boards communicating over CANBUS with each other.
On the latest boards i added some extra functionality and the pinout does not match the old boards.
What i would like to do is to create a single library for all the boards and select de right one when i program them.
I have created three files for the library: P24LSx.h, P24LSx.cpp, hardware.h
In "hardware.h" i defined the pinout for new and old boards.
The issue:
I have two boards P24LS2WS and P24LS2WH.
No mater which one i choose it always defines the last case on the switch case control structure.
Here is my code:
hardware.h
#if defined P24LS2WS
  #define HW_ERR_LED					A1
  #define HW_POWER_LED					A0
  #define HW_BUTTON_1_LED				A5
  #define HW_BUTTON_1					6
#endif
#if defined P24LS2WH
  #define HW_ERR_LED					2
  #define HW_POWER_LED					3
  #define HW_BUTTON_1_LED				5
  #define HW_BUTTON_1					4
#endif
P24LSx.h
#ifndef P24LSx_h
#define P24LSx_h
#include "Arduino.h"
enum BOARD_INFO { __P24LS2WS__, __P24LS2WH__ };
class P24LSx {
  public:
	  P24LSx(BOARD_INFO board1);
	  void begin();
  private:
#endif
P24LSx.cpp
#include "P24LSx.h"
P24LSx::P24LSx(const BOARD_INFO board1) {
  switch (board1)
	case __P24LS2WS__:
	  #define P24LS2WS
	case __P24LS2WH__:
	  #define P24LS2WH
#include "hardware.h"
void P24LSx::begin(){
  Serial.println(HW_ERR_LED, HEX);
main code
  #include <P24LSx.h>
  P24LSx lswc (__P24LS2WS__);
    lswc.begin();
I can not figure out what is the problem.
Any advice is much apreciated.
Best Regards,
Fabian
this doesn't do anything. these #defines are processed at compile not run time
either P24LS2WS or P24LSwWH need to be defined in hardware.h
hardware.h could include a .h where one of these are defined
they could be defined on the command line, but i'm not sure how to do that with the IDE
Try this
#define P24LS2WS     // to use that configuration or
// #undef P24LS2WS     // to use the other one
#ifdef P24LS2WS
#else
#endif
Remove all other references to to P24LS2WS from your code. Haven't tested this, but it should work.
