switch case jump to another loop function
Hi all,
Tried a few iterations of this without success. Can anyone see why it wont go to my other loop. I'm not a pro programmer mostly learning at the moment.
tks
//Look For errors and Halt
    byte Error = bitRead(LTC1325Status, 7);
    switch (Error) {
      case 0:
        //continue
      case 1:
        void Shutdown();
Maybe the bit is always 0. How do you know that it isn't. Your best debugging tool is the serial print.
      case 1:
        void Shutdown();
The compiler should be showing an error because you cannot declare a function inside another function. Remove the "void" before "Shutdown()" .
serial shows 1
Without the void I get
LCDML_display_menuFunction:409:18: error: too few arguments to function 'void Shutdown(uint8_t)'
Shutdown();
LCDML_display_menuFunction.ino:756:6: note: declared here
void Shutdown(uint8_t param)
    Serial.println(Error);
    switch (Error) {
      case 0:
        //continue
      case 1:
        Shutdown();
The Shutdown() function requires an argument that you are failing to supply. Is that function part of a library?
Post the whole code.
Ok attached in full, the Bit of code is in menu_Fonction tab. It is not part of a library.
Really appreciate the help
BatteryChargerV3.zip (12.8 KB)
lucatz:
I believe your LCDML thing is a library and should be treated that way:
In the LCDML_display_menuFunction, you see this:
  if (LCDML.FUNC_setup())         // ****** SETUP *********
    // remmove compiler warnings when the param variable is not used:
    LCDML_UNUSED(param);   <--- this line
As the comment suggest, the intent here is to make the compiler not care that you’ve not passed a parameter to it. The macro is defined in LCDMenuLib2.h:
    // this makro is for unused variables which exists for compatibility tings ...
    #define LCDML_UNUSED(expr) do { (void)(expr); } while (0)
I can’t vouch for the efficacy of the macro. I find it odd that LCDMenuLib2.h is not included a the top of LCDML_display_menuFunction.ino.
As a remedy to the immediate problem, you might try changing Shutdown() to:
void Shutdown( void ) // <--- change to void parameters
    //LCDML_UNUSED(param);   <--- comment out
I tried your recommendation which passes compilation but it still will not jump to shutdown loop. Had also tried if/else with goto but read it was not best way to go about it. It also did not jump to shutdown.
serial.println prints constant 1 in monitor so case 1 should trigger
tks
// Set CS Pin LOW
    digitalWrite(CS_Pin, LOW); // Activate the CS line (CS is active LOW)
    delay(1);
    //Send Command Bytes to LTC1325
    SPI.transfer(0b00000010); // Send First byte
    SPI.transfer(0b00100100); // Send Second byte
    SPI.transfer(0b00000011); // Send Third byte
    LTC1325ADC = SPI.transfer16(0b1100000000000000); // Send TX4&TX5 get RX4&RX5 result and place in LTC1325ADC
    LTC1325Status = SPI.transfer(0b00000000); // Send TX6 get RX6 result and place in LTC1325Status
    //Set CS_Pin High
    digitalWrite(CS_Pin, HIGH); // Enable internal pull-up
    //Look for Errors and Halt
    switch (Error) {
      case 0:
        Shutdown();
      case 1:
        Shutdown();
    //if (Error == 1) {
    //  lcd.clear();
    //  lcd.setCursor(1, 0);
    //  lcd.print("Error Encountered");
    //goto Shutdown();
    //else {
    //continue
    //ADC Result
    ADCResult = LTC1325ADC * (3.06 / 1024);
    lcd.clear();
    lcd.print("Charging");
    lcd.setCursor(1, 1);
    lcd.print("Vbat=");
    lcd.print(ADCResult);
    lcd.print("V");
    lcd.setCursor(1, 2);
    lcd.print("Status");
    lcd.setCursor(1, 3);
    lcd.print(LTC1325Status, BIN);
    // setup function
    lcd.setCursor(0, 0);
    lcd.print(F("To close this"));
    lcd.setCursor(0, 1);
    lcd.print(F("function press"));
    lcd.setCursor(0, 2);
    lcd.print(F("any button or use"));
    lcd.setCursor(0, 3);
    lcd.print(F("back button"));
  if (LCDML.FUNC_loop())          // ****** LOOP *********
    // loop function, can be run in a loop when LCDML_DISP_triggerMenu(xx) is set
    // the quit button works in every DISP function without any checks; it starts the loop_end function
    if (LCDML.BT_checkAny()) { // check if any button is pressed (enter, up, down, left, right)
      // LCDML_goToMenu stops a running menu function and goes to the menu
      LCDML.FUNC_goBackToMenu();
  if (LCDML.FUNC_close())     // ****** STABLE END *********
    // you can here reset some global vars or do nothing
Can you add a debug-print in Shutdown() such as:
    Serial.println( "In Shutdown" );
before any of the 'if' statements and report back?
hmm... :frowning: my debug skills are week, but I am learning :slight_smile:
So it is going to the shutdown but it is not displaying on lcd...
13:27:30.775 -> In Shutdown
13:27:32.768 -> 1
13:27:32.768 -> In Shutdown
13:27:34.110 -> 1
13:27:34.110 -> In Shutdown
david_2018:
      case 1:
    void Shutdown();
No, that’s just a function prototype.
But yes, lose the “void”
Ok
I will correct the Shutdown loop and will drop the void.
Can you guys confirm once it hits Case1 and goes to shutdown that it stays in there and never goes back to where it came from?
I see it goes to Shutdown so I think it works now
Thanks to all of you truly appreciated
Luca
lucatz:
hmm… :frowning: my debug skills are week, but I am learning :slight_smile:
So it is going to the shutdown but it is not displaying on lcd…
13:27:30.775 → In Shutdown
13:27:32.768 → 1
13:27:32.768 → In Shutdown
13:27:34.110 → 1
13:27:34.110 → In Shutdown
The only condition in Shutdown that puts anything to the LCD appears to be:
    // setup function
So why does LCDML.FUNC_setup() not return a non-zero value?
Checking the source for that function in the library:
bool LCDMenuLib2::FUNC_setup(void)
    // debug information
    DBG_println(LCDML_DBG_function_name_FUNC, F("LCDML.FUNC_setup - check"));
    if(actMenu_id != _LCDML_NO_FUNC)
        // function active
        if(bitRead(REG_MenuFunction, _LCDML_REG_MenuFunction_setup) == 0)
            DBG_println(LCDML_DBG_function_name_FUNC, F("LCDML.FUNC_setup - check: true"));
            bitSet(REG_MenuFunction, _LCDML_REG_MenuFunction_setup); // run setup
            DISP_clear();
            REG_button = 0;
            return true;
            DBG_println(LCDML_DBG_function_name_FUNC, F("LCDML.FUNC_setup - check: false"));
            return false;
        bitClear(REG_MenuFunction, _LCDML_REG_MenuFunction_setup); // run setup
        return false;
There’s only one way to return non-zero from that function:
        // function active
            DISP_clear();
            REG_button = 0;
            return true;
Follow the if’s and determine which condition is failing. It’s probably a menu initialization thing or something.
“No, that's just a function prototype”
What’s the difference between a function prototype and a function declaration?
TIA
a7
alto777:
TIA
a7
The semicolon at the end instead of the body of the function I would think.
I Modified the Shutdown Loop...But I still see in serial monitor the output from Error byte.
In the Charging Loop I have...
Then
switch (Error) {
      case 1:
        Shutdown();
So at this point it should be in Shutdown loop but I still see in serial monitor the output from serial.println
so I'm thinking it never actually leaves the Charging loop...could that be?
We can’t see your code
TheMemberFormerlyKnownAsAWOL:
We can't see your code
From Post 15? I see it...
lucatz:
I Modified the Shutdown Loop…
Can you see post #16?
Ok I see what you mean... :slight_smile:
Charging Loop
void Charging(uint8_t param)
    //LCD Print
    lcd.clear();
    //SPI for LTC1325
    pinMode(CS_Pin, OUTPUT); // set the slaveSelectPin as an output:
    pinMode(53, OUTPUT); //Insure Mega is Master
    digitalWrite(CS_Pin, HIGH); // Activate the CS line (CS is active Low)
    SPI.begin();
    SPI.beginTransaction(SPISettings(125000, MSBFIRST, SPI_MODE0));
    delay(100); //Let things stabalize
    // setup
    // is called only if it is started
    // starts a trigger event for the loop function every 100 milliseconds
    LCDML.FUNC_setLoopInterval(2000);
    // uncomment this line when the menu should go back to the last called position
    // this could be a cursor position or the an active menu function
    // GBA means => go back advanced
    LCDML.FUNC_setGBA();
    // Set CS Pin LOW
    delay(1);
    //Set CS_Pin High
    switch (Error) {
      case 1:
        Serial.println("In Case One");
        LCDML.FUNC_close();
        Shutdown();
    //ADC Result
    lcd.clear();
    lcd.print("Vbat=");
    lcd.print("V");
    // loop
    // is called when it is triggered
    // - with LCDML_DISP_triggerMenu( milliseconds )
    // - with every button or event status change
    // uncomment this line when the screensaver should not be called when this function is running
    // reset screensaver timer
    LCDML.SCREEN_resetTimer();
    // loop end
    // you can here reset some global vars or delete it
    // this function is always called when the functions ends.
    // this means when you are calling a jumpTo ore a goRoot function
    // that this part is called before a function is closed
Shutdown Loop
void Shutdown(void)
  Serial.println("In Shutdown");
    //LCD Print
    lcd.clear();
    //SPI for LTC1325
    SPI.begin();
    // setup
    lcd.clear();
    lcd.print("Shutdown");
    delay(2000);
    /* Set CS Pin LOW
      delay(1);
      //Set CS_Pin High
      switch (Error) {
      case 0:
        Shutdown();
      case 1:
        Shutdown();
      //ADC Result
      lcd.clear();
      lcd.print("Vbat=");
      lcd.print("V");
    // loop
    // loop end
I Suspect that it is not exiting the Charging loop with this code...
switch (Error) {
      case 1:
        LCDML.FUNC_close();
        Shutdown();
I think the only way to exit the loop is to call the LCDML.Func_Close , which is at the end of all loops. But It still does not work as I envisioned.
Serial shows the following...
16:33:27.475 -> 1
16:33:27.475 -> In Case One
16:33:27.475 -> In Shutdown
16:33:29.524 -> 1
16:33:29.524 -> In Case One
16:33:29.524 -> In Shutdown
16:33:31.528 -> 1
16:33:31.528 -> In Case One
16:33:31.528 -> In Shutdown
16:33:33.531 -> 1
16:33:33.531 -> In Case One
16:33:33.578 -> In Shutdown
tks
