switch case - multiple outputs with same option
Hi all
Just a quick one. If I use a switch...case statement on a variable called "test";
switch (test){
case 1:
//do thing 1
case 2:
//do thing 2
case 3:
//do thing 2
as you'll see the result of test being either 2 or 3 results in the same action. Is there a way to enter multiple outputs for a single case, eg
case 1,2:
or similar?
The Arduino supports a range option:
   case 1...2:
There is NO way to have one case statement handle discrete values that are not consecutive (i.e. 3 and 7).
No, not that way. The only way that I know is to set a range of values in the case using ellipses.
This will trigger the case on either 2 or 3. But the range must be inclusive (contiguous?).
int test = 3;
  switch (test)
    case 1:
      Serial.println("thing 1");
    case 2 ... 3:
      Serial.println("thing 2");
Paul beat me too it, but I will post my example.
But, multiple case statements can execute the same code:
switch (test) {
    case 1:
      //do thing 1
    case 2:
    case 3:
    case 13:
    case 99:
      //do thing 2
    case 11:
    case 21:
      // do thing 3
    default:
I kinda like the fall-through option gfvalvo shows because you can add comments about each case if you wish.
And now I know a new way, Thanks, gfvalvo.
Hmm...does the fall through option have to be in numerical order?
No.
