Hello,
I am using the switch/case command but it isn't triggering. Variable -suffix- is always printing "0". Variable -iVal- prints correct values as the pot is changed. Please see sketch and see what I am missing.
The code is really just the pertinent parts of a much longer sketch. Not really necessary to post for this problem. I am using the MEGA2560R3. The pot is a 10K connected to MEGA 5V and GND with the wiper to analog pin 8. I omitted 7 of the 10 cases just to shorten this post. They are repetitive.
The button scanner, as I call it, also uses switch/case which is functioning perfectly. I'm stumped.
Thank you,
1oldfox
"If it ain't broke, fix it 'til it is."
int irisValuePin = 6;
int analogPin = 8;
int suffix;
String baseString;
int iVal;
int i;
Serial.begin(9600, SERIAL_8E1);
pinMode(irisValuePin, INPUT_PULLUP);
IrisValue();
void IrisValue() //button 5 -- Dpin 6
iVal = analogRead(analogPin); //changes with pot position... verified GOOD
Serial.print("iVal = ");
Serial.println(iVal);
delay(1);
switch(iVal)
case 1: //F1.6
if (iVal > 50 & iVal < 150)
{ suffix = 0; }
case 2: //F2.2
if (iVal > 150 & iVal < 250)
{ suffix = 1; }
case 10: //F34
if (iVal > 950 & iVal < 1023)
{ suffix = 9; }
baseString = "W123456";
Serial.println(baseString);
Serial.println(suffix);
baseString += suffix;
Serial.print("\n");
while (digitalRead(6) == HIGH)
switch/case depends on an exact match for the case values to work. What values do you see for iVal ?
As it comes from an analogRead() I would be surprised if they were exactly 1, 2 ,3 etc
In fact, from your code I can see that you are not expecting them to be any such value. Take out the switch/case and just use the ifs
UKHeliBob:
While true in the sense of a compiler locked to the C/C++ standard we are after all using GCC which allows us to do -
switch ( /* an integer value here */ )
case 0 ... 9:
// ... some perhaps useful code here ...
case 10 ... 19:
case 20 ... 29:
default:
UKHeliBob
I took your advice and went with the "if" statements only. Works like a charm now. Thanks a lot. I have used switch/case many times in the past with various languages (but I'm just a newbie) so that was the first thing I tried. This is the first time I couldn't get it to work. The sketch works now but I'm still wanting to know why switch didn't work. "Inquiring minds want to know."
UKHeliBob told you:-
You only get those case to work for iVal values of 1 to 10. Then the first thing you do when the are called is check incorrectly if they are in another range altogether. Therefore nothing can ever be executed.
UKHeliBob
Check your if statements. What happens if iVal ==150?
AHA! Grumpy_Mike turned on the light for me and it's my bad. I failed to explain that I will be using the pot as a multi-position "switch". The pot will be set thusly... case 1: pot will be set to analog 100... case 2: pot will be set to analog 200... etc. etc. (And therein lies my answer) The pot will never be set to 150 or any other value other than the midpoint of each range. (e.g. 100, 200, 300, 400, 500 etc.) I apologize for not explaining this earlier. The function won't even be called until a pushbutton is pressed. That button is scanned by the other switch/case I mentioned earlier, and is working flawlessly.
Looking back at the code, I see my problem. I would have to first declare another var, (e.g. range) and set that to an integer between 1 and 10 using analogRead(). Then the switch/case var would become range, not iVal. To determine the value of "range", I would have to use the "if" statements first. Therefore switch/case becomes redundant. DUH! Oh well, like I said, I'm really a newbie at software. I'm a hardware tech.
Thanks, everyone, for the input. It did make me see what I was doing wrong. Hope this may help someone in the future. I learned something new from all of this.
Have you considered using map() to convert the 0 - 1023 input into 0 - 9 output ?
No. I have never used "map()". I'll have to learn that one. I'll give it a try. I will finally use the function that gives me the smallest code.
Thanks for the tip.
That's it! map() took a 41 line function down to 21 lines. 50% tightening. I like it. Thanks for the lead. This project is my first time using analog inputs. So the learning curve was kinda double steep.
