#define button1 5
#define button2 6
int state=2;
pinMode(button1,INPUT);
pinMode(button2,INPUT);
digitalWrite(button1, HIGH);
digitalWrite(button2, HIGH);
Serial.print("setup");
switch(state) {
case 1:
delay(800);
Serial.print("state1");
int b1 = digitalRead(button1); // if I remove these 2 lines readint buttons , machine states are updated correctly
int b2 = digitalRead(button2); // otherwise
state=2;
case 2:
Serial.print("state2");
delay(1200);
state=1;
Hello .
in this simple 2 state machine, if I put those 2 lines reading pin it stops working.
is this common knowledge Im missing ? you cant declare inside a case ?
Ive seen that declaring b1 and b2 as global it works.
thanks for the support in advance.
What happens if you enclose the following in a block as in :
case 1:
delay(800);
state=2;
Ok i will turn on compiler warnings. Thanks for the tip.
Ive been enclosing in brakets as well with no results.
The declaration inside case: reduced memory use thats why I went there...
