So I am trying to make an IR controlled LEDs box. I am using a switch/case statement to decide what to do when an IR code is received. I had written a couple for loops to loop through my three LEDs, but any of the cases below that code does not get executed. I figured it was a missing bracket but when I look through them they all appear to be in the correct spots! The last case that seems to work is
case 0xFFE21D:
Switch statement:
switch (value) {
case 0xFFA25D:
Serial.print(" >> Power button\n");
if (ledOnState) {
ledOnState = false;
digitalWrite(ledPins[0], LOW);
ledOnState = true;
digitalWrite(ledPins[0], HIGH);
case 0xFFE21D:
Serial.print(" >> Menu button\n");
turnOffAllPins();
delay(150);
int randPin = rand() % 3;
Serial.println(randPin);
if (ledOnState) {
ledOnState = false;
digitalWrite(ledPins[randPin], LOW);
ledOnState = true;
digitalWrite(ledPins[randPin], HIGH);
break; <<<<< ANYTHING BELOW THIS DOES NOT RUN.
case 0xFF22DD:
Serial.print(" >> Test button\n");
case 0xFF02FD:
Serial.print(" >> Plus button\n");
/*if (ledBrightness == 0) {
ledBrightness = 120;
} else if (ledBrightness == 120) {
ledBrightness = 140;
} else if (ledBrightness == 140) {
ledBrightness = 255;
analogWrite(ledPin, ledBrightness);*/
case 0xFFE01F:
Serial.print(" >> Rewind button\n");
case 0xFFA857:
Serial.print(" >> Play button\n");
case 0xFF906F:
Serial.print(" >> Fast forward button\n");
case 0xFF6897:
Serial.print(" >> Zero button\n");
turnOffAllPins();
case 0xFF9867:
Serial.print(" >> Minus button\n");
/*if (ledBrightness == 255) {
ledBrightness = 0;
case 0xFFB04F:
Serial.print(" >> C button\n");
case 0xFF30CF:
Serial.print(" >> One button\n");
for (int i = 0; i <= 10; i++) {
digitalWrite(ledPins[2], HIGH);
delay(150);
digitalWrite(ledPins[2], LOW);
delay(100);
case 0xFF18E7:
Serial.print(" >> Two button\n");
digitalWrite(ledPins[1], HIGH);
delay(150);
digitalWrite(ledPins[1], LOW);
delay(100);
case 0xFF7A85:
Serial.print(" >> Three button\n");
delay(150);
delay(100);
case 0xFF10EF:
Serial.print(" >> Four button\n");
case 0xFF38C7:
Serial.print(" >> Five button\n");
case 0xFF5AA5:
Serial.print(" >> Six button\n");
case 0xFF42BD:
Serial.print(" >> Seven button\n");
case 0xFF4AB5:
Serial.print(" >> Eight button\n");
case 0xFF52AD:
Serial.print(" >> Nine button\n");
case 0xFFC23D:
Serial.print(" >> Back button\n");
bool firstIteration = true;
for (int i = 0; i <=5; i++) {
if (firstIteration) {
for (int i = 0; i <= 2; i++) {
digitalWrite(ledPins[i], HIGH);
Serial.print("LED ON: ");
Serial.print(ledPins[i]);
delay(150);
digitalWrite(ledPins[i], LOW);
delay(100);
for (int i = 1; i >= 0; i--) {
delay(150);
delay(100);
firstIteration = false;
else {
for (int i = 1; i <= 2; i++) {
delay(150);
delay(100);
delay(150);
delay(100);
Edit: Added sketch as attachment.
I should clarify, I originally had my code working fine with my switch statement producing the ">> button name" for every single button on my IR remote no problem. it became problematic once I added all the code shown below. The code itself runs fine, but any other case after 0xFFE21D just does not execute anything.
case 0xFFE21D:
turnOffAllPins();
delay(150);
int randPin = rand() % 3; //From this line,
if (ledOnState) {
ledOnState = false;
ledOnState = true;
digitalWrite(ledPins[randPin], HIGH);//To this line.
IR_to_serial.ino (5.08 KB)
