switch case statement: use ranges? (case 0 to 10:)
hi!
In Visual Basic, when using a switch case statement, I can not only specify certain values, but also ranges for the analyzed value. e.g.
switch(x)
case 0 to 10: foo(); break;
case 11 to 20: bla(); break;
So far, I haven't been able to do that with the Arduino. Is there a way to achieve this without resorting to normal if statements?
switch (x) {
case 0:
case 1:
case 2:
case 3: zero_to_three_action ();
case 4:
case 5:
case 6:
case 7: four_to_seven_action ();
Is probably the best you'll manage.
if (x>=0 && x<=10){
  foo();
} else if (x>=11 && x<=20){
  bla();
@AWOL: That's actually a nice trick. however, I need to evaluate angles from -179 to 180 degrees, so that would make a REALLY long program :slight_smile: I might remember it for other uses though.
@AlphaBeta: Yeah, I guess thats what I'll be facing.
But I guess since I want to split up the angles into eight equal pieces (basically the directions up, up-right, right, down-right, etc), I can simply divide them by 45 and then use a switch case statement without much hassle :sunglasses:
maybe you can make use of the map function?
y = map(x,-179,180,1,8);
switch(y)
case 1 : ....; break;
case 2 : ....; break;
case 3 : ....; break;
case 8 : ....; break;
cheers
Peter
Good idea!
Meanwhile, I had written my own function to do it:
      dir=(int)(deg+180+22.5)/(int)45;
      if(dir==8) dir=0;
(in case anyone's interested:)
the +180 is to get 1 to 360 instead of -179 to 180.
the +22.5 degree shifts it again because e.g. I want the direction 4 (right) to span 22.5 degrees up and down starting from the horizontal axis.
this way, direction 0 is left, 1 is down-left, 2 is down, ... and 7 is up-left
This works . . .
    switch (x) {
    case 1 ... 8:                       // digits 0-8 (0 & 9 not used)
      // stuff
Not ANSI but works with Arduino. Haven't tried it with larger ranges.
