switch case switch case construct comp w errors
I want to use two switches to execute 32 different commands.
Therefore there is a switch inside a switch. But this construction compiles with errors. here’s the sketch:
// all used globals
int  baseDecoderAddress = 57;      // Default decoder address
int  testDecoderAddress ;      // Change this to 57..60
                                   // this equals turnouts 225..240
int  State = 0;                    // per address from 0..7
void setup()  {
 testDecoderAddress = 57;
void executeCommand()  {
   switch(testDecoderAddress)  {
     case baseDecoderAddress:
     switch(State)  {
       case 0:  Serial.println("225R off"); break;
       case 1:  Serial.println("225G on"); break;
       case 2:  Serial.println("226R step to next station right"); break;
       case 3:  Serial.println("226G step to next station left"); break;
       case 4:  Serial.println("227R do 180 degrees turn right"); break;
       case 5:  Serial.println("227G do 180 degrees turn left"); break;
       case 6:  Serial.println("228R turn right"); break;
       case 7:  Serial.println("228G turn left"); break;
       default: break;
     default: break;
   default: break;
void loop()  {
 executeCommand();
Do i mis something ?
No, quite the opposite - too many "default:".
Consistent indentation would help.
Could you please offer a better help. I removed all the bottom part break's at no help.
The very last 'default: break;' is not needed, so remove it.
If this doesn't work you need to post your code again.
Thanks bur now i got a other error
     switch(State)
       default:  break;
     default:  break;
And the error: sketch_dec01b.cpp: In function 'void executeCommand()': sketch_dec01b:18: error: 'baseDecoderAddress' cannot appear in a constant-expression
You can't have a variable case. Why would you want one?
The complete routine looks like this:
     switch(State)
    case baseDecoderAddress+1:
     switch(State)
       case 0:  Serial.println("229R goto station1"); break;
       case 1:  Serial.println("229G goto station2"); break;
       case 2:  Serial.println("230R goto station3"); break;
       case 3:  Serial.println("230G goto station4"); break;
       case 4:  Serial.println("231R goto station5"); break;
       case 5:  Serial.println("231G goto station6"); break;
       case 6:  Serial.println("232R goto station7"); break;
       case 7:  Serial.println("232G goto station8"); break;
    case baseDecoderAddress+2:
     switch(State)
       case 0:  Serial.println("233R goto station9"); break;
       case 1:  Serial.println("233G goto station10"); break;
       case 2:  Serial.println("234R goto station11"); break;
       case 3:  Serial.println("234G goto station12"); break;
       case 4:  Serial.println("235R goto station13"); break;
       case 5:  Serial.println("235G goto station14"); break;
       case 6:  Serial.println("236R goto station15"); break;
       case 7:  Serial.println("236G goto station16"); break;
    case baseDecoderAddress+3:
     switch(State)
       case 0:  Serial.println("237R goto station17"); break;
       case 1:  Serial.println("237G goto station18"); break;
       case 2:  Serial.println("238R goto station19"); break;
       case 3:  Serial.println("238G goto station20"); break;
       case 4:  Serial.println("239R goto station21"); break;
       case 5:  Serial.println("239G goto station22"); break;
       case 6:  Serial.println("240R goto station23"); break;
       case 7:  Serial.println("240G goto station24"); break;
    default: break;
De value of baseDecoderAddress can have 4 values starting at any value. Maybe i should invent something that that moves it to 1,2,3 and 4
Use constant cases and add in the base offset afterwards.
For testing is came up with this solution:
  // First check if the command is for this decoder
  if(testDecoderAddress > baseDecoderAddress-1 || testDecoderAddress < baseDecoderAddress+1)
      // Calculate the decoder switch value
      DecoderAddress = (testDecoderAddress - baseDecoderAddress)+1;
      executeCommand();
Think this expression will allways be true … so what is tested? Or do you need to switch the + and - ?
I am coding with the final result in mind.
As in the NMRA specs CV1 holds the short decoder address witch i simulated by baseDecoderAddress. The decoder receive software produces a receivedDecoderAddress that is simulated by testDecoderAddress.
So you are correct in the asumption that in this sketch this is always true with the numbers shown here.
It isn’t an assumption - the test will be valid for ALL values, whether they’re shown here or not!
If you want to check a range,
if (x >= minVal && x <= maxVal)
I have no idea what this means.
You are correct, i now have changed the code. Thnx
If you are interested see http://www.nmra.org/standards/DCC/standards_rps/DCCStds.html for more information.
