switch case with array problem
Hi, I am having trouble using switch case to pick up the value from my array…can anyone please help spot the problem? Thank you very much…
// These constants won’t change. They’re used to give names to the pins used:
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
//const int threshold = 400; // an arbitrary threshold level that’s in the range of the analog input
const int sensorMin = 0; // sensor minimum, discovered through experiment
const int sensorMax = 1023;
const unsigned char screen_val[10] = {0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f};
int range = {
0,1,2, 3, 4, 5, 6, 7, 8, 9, };
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
int i = 0;
// read the sensor:
int sensorReading = analogRead(A0);
// map the sensor range to a range of four options:
int i = map(sensorReading, sensorMin, sensorMax, 0, 5);
void deal(unsigned char value) {
digitalWrite(range*, !bitRead(value, i));*
  • // do something different depending on the range value:*
    _ switch (range*) {_
    _
    // case 0: // your hand is on the sensor*_
    * // Serial.println(“0”);*
    * break;*
    * case 1: // your hand is close to the sensor*
    * Serial.println(“1”);*
    * deal(screen_val[1]);
    _
    break;_
    _
    case 2: // your hand is a few inches from the sensor*_
    * Serial.println(“2”);*
    * break;*
    * case 3: // your hand is nowhere near the sensor*
    * Serial.println(“3”);*
    * break;*
    * case 4:*
    * Serial.println(“4”);*
    * break;*
    * case 5:*
    * Serial.println(“5”);*
    * break;*
    * delay(1000);*
    }[/quote]
xxx1590: Hi, I am having trouble using switch case to pick up the value from my array...can anyone please help spot the problem? Thank you very much..
Don't quote your code!
Use code tags!
xxx1590:
It looks like your intent is more like:
// These constants won't change. They're used to give names to the pins used:
//const int threshold = 400;   // an arbitrary threshold level that's in the range of the analog input
const int range[] = {
  0,1,2, 3, 4, 5, 6, 7, 8, 9, };   // Pin numbers for some kinf of output?
  for (int i=0; i<8; i++)
  digitalWrite(range[i], !bitRead(value, i));
  // read the sensor:
  switch (i) {
      Serial.println("1");
      Serial.println("2");
      Serial.println("3");
    case 4:
      Serial.println("4");
    case 5:
      Serial.println("5");
WARNING: You appear to be using Pin 1 for digital output at the same time you are using Serial. This won’t work on an Arduino UNO since Pin 0 and Pin 1 are used for Serial.
  // read the sensor:
Reading the analog pin, and mapping the reading to some other range, are a waste of effort, since the variables that hold the data immediately go out of scope.
Why did you comment out the first case statement, but not it's ending break statement?
What does the switch statement have to do with arrays, and getting the wrong value from some (undefined) array?
