switch case with timer help
larryd:
Made some cosmetic changes.
However, I tried it here, things work with using simple button switches to change the cases as I don't have a Bluetooth module right now.
Try this again, make sure you upload it to the Arduino.
#include <SoftwareSerial.h>// import the serial library
SoftwareSerial bluetooth(3, 4); // RX, TX
const int relayPin =  13;
unsigned long currentMillis;
unsigned long myRelayMillis;
unsigned long waitTime = 0;
char bluetoothData; // the data given from mobile app
boolean newData = false;
  bluetooth.begin(9600);
  pinMode(relayPin, OUTPUT);
  Serial.begin (9600); //uncomment for debugging
currentMillis = millis(); //for milli second timing
recvOneChar();
  controlWater();
void recvOneChar()
  if (bluetooth.available() > 0)
    bluetoothData = bluetooth.read();
    newData = true;
void controlWater()
  if (newData == true)
    //cancel the timer as a new command has come in
    waitTime = 0;
    newData = false;
    myRelayMillis = millis();
//is it time to process the next state code?
  if (currentMillis - myRelayMillis < waitTime)
    //No, it is not time
    return;
switch (bluetoothData)
    case '1':
        //Start watering
        digitalWrite(13, HIGH);  // turn the water on
        Serial.println("Start watering");
        waitTime = 5000;
    case '2':
        //Stop watering when timing is over
        Serial.println("Stop watering");
        digitalWrite(13, LOW);    // turn the water off
        waitTime = 5000;
    case '3':
        //Water for 1 hour
        Serial.println("Water for 1 hour");
        waitTime = 5000ul;  //testing
        //waitTime = 1 * 60 * 60 * 1000ul;
        bluetoothData = '2';
    case '4':
        //Water for 2 hours
        Serial.println("Water for 2 hours");
        //waitTime = 10000;  //testing
        waitTime = 2 * 60 * 60 * 1000ul;
    case '5':
        //Water for 3hours
        Serial.println("Water for 3 hours");
        //waitTime = 15000;  //testing
        waitTime = 3 * 60 * 60 * 1000ul;
} //END of switch/case
} //END of function
Just tried this code now, and still wont turn relay off when set time is passed.
As I mentioned it works here.
Please show us a good image of your hardware wiring so we can see how things are connected.
Memnon:
It is my guess your Bluetooth sends more than one character, perhaps a \r at the end of a transmission.
Try this, it refuses characters not equal to '1'-'5'.
char currentState;
  recvOneChar();
  controlWater();
void recvOneChar()
    //limit BT data to '1'-'5'
    if (bluetoothData > '0' && bluetoothData < '6')
      newData = true;
      currentState = bluetoothData;
void controlWater()
    waitTime = 0;
    newData = false;
    return;
  switch (currentState)
    case '1':
        //Start watering
        waitTime = 5000;
    case '2':
        waitTime = 5000;
    case '3':
        //Water for 1 hour
        currentState = '2';
    case '4':
        //Water for 2 hours
        currentState = '2';
    case '5':
        //Water for 3hours
        currentState = '2';
} //END of function
larryd:
char currentState;
recvOneChar();
  controlWater();
void recvOneChar()
      newData = true;
void controlWater()
    waitTime = 0;
    newData = false;
    return;
    case '1':
        //Start watering
        waitTime = 5000;
    case '2':
        waitTime = 5000;
    case '3':
        //Water for 1 hour
        currentState = '2';
    case '4':
        //Water for 2 hours
        currentState = '2';
    case '5':
        //Water for 3hours
        currentState = '2';
} //END of function
YES Now it works as i want :slight_smile: :slight_smile: :slight_smile: :slight_smile:
Many many thanks
Memnon:
Many many thanks
We sometimes have an argument here about whether using the delay() function is a good thing for new people to learn about.
In this case, your original sketch did use delay() which hid a few potential bugs as it freezes code execution.
In this case it didn’t read the extra BT characters that are sent at the end of the message.
Once delay() was removed, the controller is fast enough to process all characters that arrive, hence screwing up receive logic.
We therefore had to limit the received characters to 1-5.
Now it’s your turn.
For payment, you must answer the questions below:
waitTime = 0; <----<<<< Explain why this is necessary:
    waitTime = 0;
    newData = false;
    return;
What do these lines do?
myRelayMillis = millis(); //<----<<<<
    case '1':
        // Start watering
        waitTime = 5000;
    case '2':
        waitTime = 5000;
What do these lines do for the code?
waitTime = 5000;
    case '2':
        waitTime = 5000;
What does this line do?
Why is it necessary?
void recvOneChar()
      newData = true;
If you turn on the water by sending a ‘1’ to the Arduino how can you make sure it will not keep running forever if you walk away?
    case '1':
        //Start watering
        //every 1/2 second
        waitTime = 500;
larryd:
Now it’s your turn.
waitTime = 0; <----<<<< Explain why this is necessary: Cancel current timer to recive new data
    waitTime = 0;
    newData = false;
    return;
**What do these lines do? capture the latest value of millis**
**myRelayMillis = millis(); //<----<<<<**
case '1':
        // Start watering
        waitTime = 5000;
case '2':
        waitTime = 5000;
**What do these lines do for the code? Im not sure about this one.**
**myRelayMillis = millis();**
**waitTime = 5000;**
    case '2':
        waitTime = 5000;
**What does this line do?**
**Why is it necessary?**
**currentState = bluetoothData; it tells what state to go to from recived bluetooth data**
void recvOneChar()
      newData = true;
**If you turn on the water by sending a ‘1’ to the Arduino how can you make sure it will not keep running forever if you walk away?**
we can set a timer on it like the other states, but higher. Lets say 5hours max
    case '1':
        //Start watering
        //every 1/2 second
        waitTime = 500;
Yes and this is necessary as we want to ensure the timing check falls through the following 'if' statement.
 waitTime = 0;
 newData = false;
 return;
It does do that but more important, it resets the timing
i.e. if we set myRelayMillis = millis() then the math that follows is:
millis() - millis() < 0, which restarts the timing sequence.
case '1':
     // Start watering
     waitTime = 5000;
 case '2':
     waitTime = 5000;
waitTime = 5000;
Without these two lines the case '1' and case '2' would update at microsecond speed.
Now there is nothing wrong with this, however it slows program execution down.
waitTime = 5000 sets the timer to 5 seconds or in other words, the case will run every 5 second.
This is more than adequate, hence the water is turned OFF every 5 seconds as in this case.
 case '2':
     waitTime = 5000;
Yes but more important if we used 'switch (bluetoothData)' instead of 'switch (currentState)'
a BT received character such as '\r' or '\n' would mess our logic flow up.
void recvOneChar()
   newData = true;
If you turn on the water by sending a '1' to the Arduino how can you make sure it will not keep running forever if you walk away?
we can set a timer on it like the other states, but higher. Lets say 5 hours max
Yes, I would suggest you do something like this:
//set maximum on time to 5 hours
waitTime = 56060*1000ul;
currentState = '2';
 case '1':
     //Start watering
     //every 1/2 second
     waitTime = 500;
Would you do me a favor and check this works with your BT module.
Note: add a LED with a 220R resistor on pin D12 going to GND
This LED is a heart beat LED and shows you the code is executing.
Please give us a link to the BT module that you are using.
const int heartBeatLED = 12;
unsigned long heartBeatMillis;
unsigned long heartBeatDelay = 500ul;
unsigned long waitTime       = 1000ul;
unsigned long maxTime        = 4 * 60 * 60 * 1000ul;
char bluetoothData;      //the data given from mobile app
char currentState = '2'; //startup by stoping watering
  //connect a relay circuit to the relayPin
  //connect a LED from the pin to GND through a 220R resistor
  pinMode(heartBeatLED, OUTPUT);
} //END of                s e t u p ( )
  //some code to see if the sketch is blocking
  //toggle the heartBeatLED every 1/2 second
  if (currentMillis - heartBeatMillis >= heartBeatDelay)
    //reset the timing
    heartBeatMillis = heartBeatMillis + heartBeatDelay;
    digitalWrite(heartBeatLED, !digitalRead(heartBeatLED));
  //None blocking code goes here
  recvOneChar();
  controlWater();
} //END of                 l o o p ( )
void recvOneChar()
  //Debug using the Serial monitor
  //if (Serial.available() > 0)
  //  bluetoothData = Serial.read();
  //using BlueTooth
    //limit BT data to '1' through '5'
      newData = true;
} //END of            r e c v O n e C h a r ( )
void controlWater()
  //was there new data received
    newData  = false;
    waitTime = 0;
    return;
    case '1':
        //Start watering
        //reset the timer
        //maximum of 4 hours allowed
        waitTime = maxTime;
        currentState = '2';
    case '2':
        //Stop watering
        //reset the timer
        //every 1/2 second
        waitTime = 500;
    case '3':
        //Water for 1 hour
        //reset the timer
        waitTime = 5000ul;  //debug
        currentState = '2';
    case '4':
        //Water for 2 hours
        //reset the timer
        waitTime = 10000;  //debug
        //waitTime = 2 * 60 * 60 * 1000ul;
        currentState = '2';
    case '5':
        //Water for 3 hours
        //reset the timer
        waitTime = 15000;  //debug
        //waitTime = 3 * 60 * 60 * 1000ul;
        currentState = '2';
    default:
        //default stuff here
} //END of             c o n t r o l W a t e r ( )
larryd:
   //reset the timing
 recvOneChar();
 controlWater();
void recvOneChar()
//using BlueTooth
     newData = true;
void controlWater()
   newData  = false;
   waitTime = 0;
   return;
   case '1':
       //Start watering
//reset the timer
       waitTime = maxTime;
       currentState = '2';
   case '2':
       //Stop watering
//reset the timer
//every 1/2 second
       waitTime = 500;
   case '3':
       //Water for 1 hour
//reset the timer
       currentState = '2';
   case '4':
       //Water for 2 hours
//reset the timer
       currentState = '2';
   case '5':
       //Water for 3 hours
//reset the timer
       currentState = '2';
default:
Yes this code works fine. LED is pulsating
Link for bluetooth module
Thank you.
Suggest you 'not' use delay() in your future sketches unless its rarely executed and only for a short period of time such as delay(10); (10 milliseconds).
Good luck with the project.
I looked into the OP's sketch and had an idea to move most of the logic in the watering control over to the user input. That turns the user input into processed user input and the watering control into an easily interrupted watering timer.
Example uses serial monitor IO (no BT) and led13 (no relay) to show watering with timed 1, 3, and 5 second periods.
Check the time stamps in the output to show actions matching commands. Note that 1 turns the water on w/o timer.
// test of watering sketch
// test does not require BT and I have no BT to check that with so for now no BT
// #include <SoftwareSerial.h>// import the serial library
// SoftwareSerial bluetooth(3, 4); // RX, TX
unsigned long wateringStartMs = 0;
unsigned long wateringPeriod = 0;
  //  bluetooth.begin( 9600 );             // can it not run faster?
  pinMode( relayPin, OUTPUT );
  Serial.begin ( 9600 ); //uncomment for debugging
  userCommand();
  waterTimer();
inline void userCommand() // convert user input into control values
  if ( Serial.available() > 0 )
    Serial.print(F( "user input 0x" ));
    Serial.print( bluetoothData, HEX );
    Serial.println(F( " hex" ));
    case '1':
        digitalWrite( relayPin, HIGH );   // turn the water on
        Serial.print( millis());
        Serial.println(F( " Command start watering with no timer." ));
        wateringPeriod = 0; // does not use the timer, shuts timer off
    case '2':
        Serial.println(F( " Stop watering" ));
        digitalWrite( relayPin, LOW );    // turn the water off
        wateringPeriod = 0; // shuts timer off
    case '3':
        Serial.println(F( " Water for 1 second" ));
        wateringPeriod = 1000;    // wait for x second
        wateringStartMs = millis();
    case '4':
        Serial.println(F( " Water for 3 seconds" ));
        wateringPeriod = 3000;    // wait for x second
    case '5':
        Serial.println(F( " Water for 5 seconds" ));
        wateringPeriod = 5000;    // wait for x second
inline void waterTimer()
  if ( wateringPeriod > 0 )
    if ( millis() - wateringStartMs < wateringPeriod )
      return;  // keep watering
      Serial.println(F( " Watering time is over" ));
      wateringPeriod = 0;
      return;
static is a better choice than inline. It keeps the name out of the global scope avoiding any potential conflicts and the compiler does a fine job of choosing when to inline.
Liberal use of static to keep things out of the global scope is always a good choice.
TYVM CB! Karma for you!
All I remembered was that inline meant don't make this a call and return function.
GoForSmoke:
You are welcome!
In my experience with avr-gcc inline is useless: the compiler is very aggressive about inlining and always will if it makes sense.
The opposite is actually true. If the compiler inlines and the function should not be it is rather annoying to get it to stop.
This compiler is a bit of a pain at times. I learn much to avoid as well as to do and then some new version shifts things seemingly just to keep it fresh so we won't get bored.
But nah, really it is improvements! By 1.6 I no longer regretted leaving 0023.
