switch (variable) {
case 1: B break;
case 2: C break;
default: D break;
E
soooo... the procedure is running and the code runs as;
A E A E A E A E (until the variable is reached, then B or C)
[switch is ignored until the variables are matched]
or
A D E A D E A D E (until the variable is reached, then B or C)
default switch is included in the loop until a variable is reached]
or
A D D D D D ( until the variable is reached, then B or C) then E
[switch locks the default until the variable breaks it out]
In that snippet of code, the order would be A, D, E, A, D, E,.... The variable in the switch statement has the value 0 so the default case code would be executed.
If you increment variable, then the order would be A, B, E, A, B, E,...
Increment again to get A, C, E, A, C, E,...
Increment again to once again get A, D, E, A, D, E,...
No, A is always called as is E However you have used the default statement which matches every value other there than the ones on the switch labels So in your case you get d if it not 1 or 2.
ok, so this isn't running as smoothly as i'd like!
i've sacked off A and E and i'm running the whole thing inside a switch.
i have 4 modes;
1 - fade in leds upwards
2 - fade in leds downwards
3 - fade out all leds
4 - all leds stay off
int switchbutton = 0;
switch (whichbutton) {
case 1: // bottom step
// ACCENT LIGHTING
// UP LIGHTING
// LANDING LIGHTING
whichbutton = 3;
case 2: // top step
// ACCENT LIGHTING
// DOWN LIGHTING
whichbutton = 3;
case 3: // all off
// STEPS OFF
// LANDING OFF
// ACCENT OFF
whichbutton = 0;
default: // all off
// ALL LEDS OFF
} end of switch
so the running system is; 2 buttons (which button) trigger case 1 (whichbutton = 1) , or case 2 (whichbutton = 2) respectively, and then following case 1, or case2, whichbutton is set to 3 (whichbutton = 3) at the end of case3 whichbutton is set to 0, and defaults to all off.
what i seem to get is when which button is set to 3 inside the switch routine, it takes a couple of runs to realise and then jump to case 3, when in case 3 it takes a few runs and then it jumps to case 0, all off.
