Switch - Case
Example:
Switch(hour){
case ((>=6)&&(<=10)):
minTemp = (minTemp +( inc*3));
I’d like to avoid writing a long list of cases but I can’t get this to work. Is it possible?
Use ellipses to make a case with a range of values
case 6 ... 10: // note space before and after ...
I’d have done it like this, before I read Groundfungus’ post. Now I see there is an alternative way.
if ( hour >= 6 && hour <= 10 ) {
else if ( hour >= 11 && hour <= 14 ) {
else if ( hour >= 15 && hour <= 19 ) {
else {
   // default
What is the result of anything like this:
((>=6)&&(<=10))
It will be 0 or 1. This is legal, because it results in a compile time integer, but you will be restricted to 2 cases.
You can use the ellipse notation, but that is a gcc extension, and not standard.
case 6:
case 7:
case 8:
case 9:
case 10:
Is the correct, portable way. (Though you can put them all on one line.)
I take the point that it is rubbish but I was in a quandary!!! I am no expert in C++ - did you guess?
How exactly would your suggestion appear on a single line?
I have another problem and I’ll put it in the only way I know how,
switch (hour){
case ((>=18 && <=23)||(>=0 && <=5)):
It’s gobbledegook I know, but I want an ‘off’ condition between 6pm and 6am.
As pointed out above, I think you need if/else and not switch/case.
But for what you want:
switch (hour)
    case 6: case 7: case 8: case 9: case 10:
        // stuff
    case 0: case 1: case 2: case 3: case 4: case 5:
    case 18: case 19: case 20: case 21: case 22: case 23:
       //stuff
    default:
       // error!
