Hi!
I'm really new to Arduino, and I'm trying to make a little matching LEDs game, the main point is controlling one RGB LED brightness with 3 buttons(one for each rgb color), and trying to match the brightness of the second RGB LED.
I got the buttons working to change the brightness of the first LED from an array of 4 different values, so I created switch cases to set the values to match for the second LED(using the same array), and change to the next value once we get brightness matched.
The problem is that it gets stuck on the first case "correctAnswer1", and even when the other LED matched the values, it doesn't change to the next case "correctAnswer2". ![]()
Hope I explained myself somehow, thank you!
#define rPin 11
#define gPin 10
#define bPin 9
#define rPin2 6
#define gPin2 5
#define bPin2 3
#define rBtn 8
#define gBtn 7
#define bBtn 4
#define SAMPLING 200 //200milliSecond per press, used for debouncing
//cases
const int prepareGame = 0;
const int beginGame = 1;
const int correctAnswer1 = 2;
const int matchedAnswer1 = 3;
const int correctAnswer2 = 4;
const int matchedAnswer2 = 5;
const int correctAnswer3 = 6;
const int matchedAnswer3 = 7;
const int correctAnswer4 = 8;
const int matchedAnswer4 = 9;
const int correctAnswer5 = 10;
const int matchedAnswer5 = 11;
const int allMatches = 12;
static unsigned long TIMER = 0; //record current millis()
byte brightState = 0; //val used to check current status of pushbutton
byte brightness[] = {0, 75, 150, 255}; //array for the pushbuttons
pinMode(rPin, OUTPUT);
pinMode(gPin, OUTPUT);
pinMode(bPin, OUTPUT);
pinMode(rPin2, OUTPUT);
pinMode(gPin2, OUTPUT);
pinMode(bPin2, OUTPUT);
pinMode(rBtn, INPUT);
pinMode(gBtn, INPUT);
pinMode(bBtn, INPUT);
void pushButtons()
if(millis() - TIMER >= SAMPLING) //sampling ~= 250mS
TIMER = millis();
if(digitalRead(rBtn) == HIGH) //button pressed, pulled high
brightState++; //increment state
if(brightState > 3) //want only 4 brightness options, 0, 1, 2, 3
brightState = 0;
analogWrite(rPin, brightness[brightState]);
if(digitalRead(gBtn) == HIGH) //button pressed, pulled high
brightState = 0;
analogWrite(gPin, brightness[brightState]);
if(digitalRead(bBtn) == HIGH) //button pressed, pulled high
brightState = 0;
analogWrite(bPin, brightness[brightState]);
void matchingLed(){
static int state = prepareGame;
switch (state){
case prepareGame:
analogWrite(rPin2, brightness[0]); //set the leds to 0
analogWrite(gPin2, brightness[0]);
analogWrite(bPin2, brightness[0]);
state = beginGame;
case beginGame: //set the second LED on the first brightness to matched
if((digitalRead(rBtn) == HIGH) || (digitalRead(gBtn) == HIGH) || (digitalRead(bBtn) == HIGH)){
state = correctAnswer1;
case correctAnswer1:
analogWrite(rPin2, brightness[3]); //this is where it stays
analogWrite(gPin2, brightness[0]); //even when rPin, gPin & bPin are on those values
state = matchedAnswer1;
case matchedAnswer1:
if((rPin == brightness[3]) && (gPin == brightness[0]) && (bPin == brightness[0])){
state = correctAnswer2;
case correctAnswer2:
analogWrite(rPin2, brightness[1]);
analogWrite(gPin2, brightness[2]);
analogWrite(bPin2, brightness[3]);
state = matchedAnswer2;
case matchedAnswer2:
if((rPin==brightness[1]) && (gPin==brightness[2]) && (bPin==brightness[3])){
state = correctAnswer3;
case correctAnswer3:
analogWrite(gPin2, brightness[1]);
state = matchedAnswer3;
case matchedAnswer3:
if((rPin==brightness[3]) && (gPin==brightness[1]) && (bPin==brightness[0])){
state = correctAnswer4;
case correctAnswer4:
analogWrite(rPin2, brightness[2]);
analogWrite(bPin2, brightness[2]);
state = matchedAnswer4;
case matchedAnswer4:
if((rPin==brightness[2]) && (gPin==brightness[2]) && (bPin==brightness[2])){
state = correctAnswer5;
case correctAnswer5:
analogWrite(gPin2, brightness[3]);
state = matchedAnswer5;
case matchedAnswer5:
if((rPin==brightness[0]) && (gPin==brightness[3]) && (bPin==brightness[0])){
state = allMatches;
case allMatches:
//here is going to be some kind of reward, still thinking
state = prepareGame; //return to the first case to begin again
void loop(){
matchingLed();
pushButtons();
