Switch from main function to setup and loop functions to control servo
Hello,
I have to do a project that has to be written mainly in register level, with some exception that can be written in arudino code. I'm using a nano, so ATmega328P. I found this code that does the basic thing I need to do and I'm trying to build on it.
#include <avr/io.h>
#include <util/delay.h>
int main(void) {
  DDRB |= 1 << PINB1; // Set pin 9 on arduino to output
  /* 1. Set Fast PWM mode 14: set WGM11, WGM12, WGM13 to 1 */
  /* 3. Set pre-scaler of 8 */
  /* 4. Set Fast PWM non-inverting mode */
  TCCR1A |= (1 << WGM11) | (1 << COM1A1);
  TCCR1B |= (1 << WGM12) | (1 << WGM13) | (1 << CS11);
  /* 2. Set ICR1 register: PWM period */
  ICR1 = 39999;
  /* Offset for correction */
  int offset = 800;
  /* 5. Set duty cycle */
  while(1) {
    OCR1A = 3999 + offset;
    _delay_ms(1000);
    OCR1A = 1999 - offset;
    _delay_ms(1000);
  return 0;
The code works and everything when I upload it. However, when I change the int main to void setup() and remove the return, it doesn't work. I tried putting what's in the while loop to void loop(), but still doesn't work. Any idea why it's not working and what should I do to fix it? I know it sounds like something simple, but I've been trying for several hours now and still no luck. I'm trying to learn how to do this.
#include <avr/io.h>
#include <Arduino.h>
  ICR1 = 39999;
void loop(){
  int offset = 800;
  while(1) {
    _delay_ms(1000);
    _delay_ms(1000);
I'm not getting any errors. It's just not doing anything.
  TCCR1A = (1 << WGM11) | (1 << COM1A1);
  TCCR1B = (1 << WGM12) | (1 << WGM13) | (1 << CS11);
Arduino preconfigures the timers. You need to clear that by using = instead of |=.
WOW! I've been looking at this and trying different configurations for well over 5 hours and didn't come up with anything. What you did worked perfectly. I actually posted this on other forums and no one there was able to help. THANK YOU!
