Switch is not working
The switch is not working, it seems that the servo motor works itself before i open the switch, any help will be appreciated. Thanks. The code is as below:
int buttonPin = 8;
#include <Servo.h>
int servoPin = 9;
Servo servo;
int angle = 0; // servo position in degrees
int state=1;
int button =LOW;
boolean lastButton = LOW;
boolean currentButton = LOW;
long currentTime;
long previousTime;
pinMode(buttonPin, INPUT);
servo.attach(servoPin);
boolean debounce (boolean last)
boolean current = digitalRead(buttonPin);
if (last != current)
delay(5);
return current;
button = digitalRead(buttonPin); //normally open switch
currentTime = millis();
currentButton = debounce(lastButton);
if (lastButton ==LOW && currentButton == HIGH)
switch(state)
case 1 :
if (button == HIGH)
previousTime=currentTime;
state=2;
case 2 :
if (currentTime - previousTime > 2000)
Liftup();
state=3;
default:
lastButton = currentButton;
void Liftup()
servo.write(-90);
Give us a break.
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” icon above the posting area. It is the first icon, with the symbol: </>
How to use this forum
That has to be the silliest way I have ever seen code posted. Bar none.
Did you even read your own post?
Alrighty. I am sorry since this is my first post. I will remake another forum. Thanks
Arg, not remake! Edit! It's digital, not paper....
y3nadruino:
Bye.
Cross-posted here
