I have to control a small asynchronous mechanical timer that runs on 240v with a arduino. I basically need a relay of some sort to enable the timer. Because of space requirements, a mechanical relay will not fit, as for a triac with optocoupler. Since a optocoupler is a sort of triac, could I use that to drive the motor directly? It's a <3w motor, so it only sources about 0.02 amps. Could this work? Or do you guys suggest another aproach?
Most drivers specify they are not suitable for that. And especially with inductive loads like a motor.
Although I do like a Triac, do note there are tiny relays as well. And, especially because the load you want to drive is so low, this might be a lot easier then driving a triac.
The [u]MOC3043[/u] (and similar) are basically TRIACs and they have an "Absolute Maximum peak repetitive surge current" of 1A, so that would be worth a try.
A "regular" opti-isolator has a phototransistor so it doesn't work on AC.
Thanks for your replies!
I also looked at the moc30xx opticouplers, and also read that they should not be used to drive a load. Tiny relays are quite expensive, I am looking for something <20 cents bulk.
