I have an M-Audio 25 key midi controller that I wanted to use as an input device for my Arduino. The keyboard is actually a 8x8 matrix with each key cosponsoring to 2 switches, so the keyboard actually functions as a 8x4 matrix. After a bit of time with the keyboard and my multimeter, bread board, the midi table at midi.org and the midi out article at ITP I managed to put together the following code to make a simple Arduino based midi controller (complete with ridiculously neat syntax):
[ch65279]//***********************************************************************************************//
// Name : Matrix MIDI Keyboard //
// Author : Inky the Hooloovoo //
// Version : 1.1 //
// Notes : Code to use a 8 x 4 switch matrix keyboard as input for an Arduino board //
int HotPin[8] = {2,3,4,5,6,7,8,9}; //Hot (output) pins //
int GndPin[4] = {10,11,12,13}; //Ground (input) pins //
int OldKeyPress[32] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; //
int NewKeyPress[32] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; //
int KeyNum = 1; //Identifies the key being read //
int MidiNote = 60; //The MIDI note to be played (Middle C is 60) //
void setup() //
Serial.begin(31250); //Start transmiting serial data for MIDI //
for (int i=0; i <= 3; i++) //
pinMode(HotPin[i], OUTPUT); //Set pins 2 through 5 as output pins //
pinMode(HotPin[i+4], OUTPUT); //Set pins 6 through 9 as output pins //
pinMode(GndPin[i], INPUT); //Set pins 10 through 13 as input pins //
void loop() //
for (int h=0; h <= 7; h++) //
digitalWrite(HotPin[h], HIGH); //
for (int g=0; g <=3; g++) //
KeyNum = (g * 8) + h; //Sets KeyNum to a value from 0 to 31 (C1 is 04) //
NewKeyPress[KeyNum] = digitalRead(GndPin[g]); //Find out if the key if pressed //
MidiNote = KeyNum + 56; //Makes C1 on the keyboard middle C //
if (NewKeyPress[KeyNum] == 1 && OldKeyPress[KeyNum] == 0) //If key is pressed //
MidiMessage(0x90, MidiNote, 0x70); //note on, channel 1 //
else if (NewKeyPress[KeyNum] == 0 && OldKeyPress[KeyNum] == 1) //If key is released //
MidiMessage(0x80, MidiNote, 0x70); //note off, channel 1 //
OldKeyPress[KeyNum] = NewKeyPress[KeyNum] //Set state for next check //
void MidiMessage(char cmd, char data1, char data2) //
Serial.print(cmd, BYTE); //
Serial.print(data1, BYTE); //
Serial.print(data2, BYTE); //
I'll try to make a schematic when I get the chance. This code also has a major draw back in the fact that it uses up almost all of the digital i/o pins so I'll also be trying to incorporate 74HC595 and/or CD4021BE into the circuit to free up some of the pins for other uses.
