Switch mouse problems no solution
I have built a gaming controller out of the arduino esplora and a 5 position switch, using the five position switch to control the mouse(switch mouse style), however when plugged in it just moves the mouse cursor down for some weird reason can somebody please help
here is my code with explanations included
#include <Esplora.h>
#include <Mouse.h>
#include <Keyboard.h>
 const int upButton = 20;       // do I really need to take notes on this one for myself
 const int downButton = 1;     // Dude if I cant understand this it's hopeless
 const int leftButton = 28;   //
 const int rightButton = 10; //
 const int mouseButton = 21;//
 int range = 5;
 int responseDelay = 10;
boolean buttonStates[8];
const byte buttons[] = {
JOYSTICK_DOWN,
JOYSTICK_LEFT,
JOYSTICK_UP,
JOYSTICK_RIGHT,
SWITCH_RIGHT,
SWITCH_LEFT,
SWITCH_UP,
SWITCH_DOWN,
const char keystrokes[] = {
'S',
'A',
'W',
'D',
'Q',
0x09,
'E',
'v'
//You can change the keys to whatever you want.
  pinMode(upButton, INPUT);        // tells arduino that this constant is input
  pinMode(downButton, INPUT);     // tells arduino that this constant is input
  pinMode(leftButton, INPUT);    // tells arduino that this constant is input
  pinMode(rightButton, INPUT);  // tells arduino that this constant is input
  pinMode(mouseButton, INPUT); // tells arduino that this constant is input
  Mouse.begin();              // take control of the mouse
  Keyboard.begin();          // takes control of keyboard
void loop(){{
  int upState = digitalRead(upButton);
  int downState = digitalRead(downButton);
  int rightState = digitalRead(rightButton);
  int leftState = digitalRead(leftButton);
  int clickState = digitalRead(mouseButton);
  int xDistance = (leftState - rightState) * range;
  int yDistance = (upState - downState) * range;
  if((xDistance != 0) || (yDistance != 0)){
    Mouse.move(xDistance, yDistance, 0);
  // if the mouse button is pressed:
  if (clickState == HIGH) {
    // if the mouse is not pressed, press it:
    if (!Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.press(MOUSE_LEFT);
  // else the mouse button is not pressed:
  else {
    // if the mouse is pressed, release it:
    if (Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.release(MOUSE_LEFT);
  // a delay so the mouse doesn't move too fast:
  delay(responseDelay);
    int valueSlider = Esplora.readSlider();
    if(digitalRead(valueSlider) > 800){
      Keyboard.press('R');
       Keyboard.release('R');
//BELOW THIS LINE IS AKASH'S STUFF DO NOT TWEAK
for(byte thisButton = 0; thisButton < 8; thisButton++) {
boolean lastState = buttonStates[thisButton];
boolean newState = Esplora.readButton(buttons[thisButton]);
if (lastState != newState) {
if (newState == PRESSED) {
Keyboard.press(keystrokes[thisButton]);
else if (newState == RELEASED) {
Keyboard.release(keystrokes[thisButton]);
buttonStates[thisButton] = newState;
delay(50);
int yAxis = Esplora.readAccelerometer(Y_AXIS);
if (yAxis >= -15) { Keyboard.press(KEY_LEFT_SHIFT); delay(50);
Keyboard.release(KEY_LEFT_SHIFT);
if (yAxis <= 15) {
Keyboard.press(KEY_LEFT_CTRL);
delay(50);
Keyboard.release(KEY_LEFT_CTRL);
delay(50);
How are the switches wired ?
Do you have pulldown resistors in place to keep the pins LOW when the switches are not closed ?
int so you can handle all 256+ states of the switch?
