switch { } need help
"break" means, break out of this bit of code.
take this for example:
int i = 0;
while(1){
  i++;
  if (i == 10){
    break; //when i = 10, the break statement is executed and the code jumps...
//... to here.
Switches are just a convinient way of performing actions depending on the value of a variable.
int j = 2
switch (j)
     case 1:
     //  blah
     break;
    case 2:
    // blah
    break;
    case 3:
    // blah
    break;
could be equally written as:
int j = 2
if (j == 1){
     //  blah
} else if (j == 2){
    // blah
} else if (j == 3){
    // blah
The two differ when you end up with other operators such as > or <. This works as an if, but not as a switch:
int j = 2
if (j <= 1){
     //  blah
} else if (j <= 2){
    // blah
} else if (j <= 10){
    // blah
Another use of a switch, which can't be done with if() is something like this:
   switch (nodeOperation) {
        case  NSNodeNodeBNetA:
            //Swap them around so we can use the same code.
            tempNode = nodeA;
            nodeA = nodeB;
            nodeB = tempNode;
        case  NSNodeNodeANetB:
            //Do some stuff here...
            break;
        case  NSNodeKeepMajor:
            if (nodeA.net.components.count >= nodeB.net.components.count) {
                tempNode = nodeA;
                nodeA = nodeB;
                nodeB = tempNode;
            //the nodes are now backwards (node B should be where nodeA is and vice versa) but this will be corrected on fall through
        case  NSNodeNodeBNetB:
            //swap the nodes around to reduce the amount of code required.
            tempNode = nodeA;
            nodeA = nodeB;
            nodeB = tempNode;
        case  NSNodeNodeANetA:
            //do some stuff here.
            break;
        case  NSNodeWireMajor:
                tempNode = nodeA;
                nodeA = nodeB;
                nodeB = tempNode;
        case  NSNodeWireWithB:
            tempNode = nodeA;
            nodeA = nodeB;
            nodeB = tempNode;
        case  NSNodeWireWithA:
            break;
        case  NSNodeDontMerge:
        default:
            return nil; //Cant do this operation as it isn't defined, also, the 'Dont Merge' option comes here
By using a switch, I saved a lot of code, as all though there are 9 cases, those cases are essentially grouped into three, the difference being that nodeA and nodeB were switched. So by relying on fall-through as it is known (no break;), the nodes could be switched and use the same code.
(Oh, in case anyone recognises the NS reference in that last bit of code, it is actually written in objective-C, but I have stripped it down to a point which it is perfectly valid in C++ as well.)
