Hello!
I am trying to get this sketch to work as intended, but there are a few problems:
in switch (cmd) only case 't': works; case 'l' and default do not work;
Serial.read() in case 'l' does not read anything when sending l1, but actually 1 in l1 is read by the first Serial.read() on the next loop() iteration;
The same happens if I use if - else if - else: only the t command can be invoked.
I am using Arduino IDE 1.8.19 on Majaro Linux and I selected Arduino AVR Boards -> Arduino Pro or Pro Mini.
The sketch is compiling without errors.
What could be the problem here?
// Use SI!
// Device: t
#include "OneWire.h"
#include "DallasTemperature.h"
#define T 5
OneWire w1(T);
DallasTemperature sensors(&w1);
// end device
// Device: l
// LED_BUILTIN, pin 13
// end device
sensors.begin();
pinMode(LED_BUILTIN, OUTPUT);
char cmd;
char arg;
if (Serial.available()) {
cmd = Serial.read();
switch (cmd) {
case 't':
sensors.requestTemperatures();
float t = sensors.getTempCByIndex(0);
Serial.print("t:");
Serial.println(t);
case 'l':
arg = Serial.read();
switch (arg) {
case '0': digitalWrite(LED_BUILTIN, LOW);
case '1': digitalWrite(LED_BUILTIN, HIGH);
default:
Serial.print("Available commands:_");
Serial.print("\tt -> read temperature;_");
Serial.print("\tl0 -> turn built-in led off;_");
Serial.print("\tl1 -> turn built-in led on;_");
If you declare a variable with an initializer within a case, the enclose the statements within that case in brackets to limit the scope of the variable. Otherwise, the scope of the variable is the remainder of the switch/case, but the compiler will not let you execute any subsequent case because it sees a variable that has skipped its initialization.
Your problem with reading L1 is that the code executes so fast that the 1 is still being sent when you have read the L and are checking to see if there is another character in the serial buffer.
This actually fixed it. However, the compiler did not complain.
switch (cmd) {
case 't':
Serial.print("t:");
Serial.println(t);
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved2024127-12464-1syj54n.dqsuh\sketch_feb27a\sketch_feb27a.ino: In function 'void loop()':
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved2024127-12464-1syj54n.dqsuh\sketch_feb27a\sketch_feb27a.ino:37:18: warning: jump to case label [-fpermissive]
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved2024127-12464-1syj54n.dqsuh\sketch_feb27a\sketch_feb27a.ino:33:23: note: crosses initialization of 'float t'
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved2024127-12464-1syj54n.dqsuh\sketch_feb27a\sketch_feb27a.ino:48:13: warning: jump to case label [-fpermissive]
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved2024127-12464-1syj54n.dqsuh\sketch_feb27a\sketch_feb27a.ino:43:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved2024127-12464-1syj54n.dqsuh\sketch_feb27a\sketch_feb27a.ino:44:25: note: here```
Win 10, IDE 2.2.1 with verbose compiler warnings turned on in IDE Preferences
